converting HUE (HSV) to RGB and hex
Posted: Monday 14 March 2016 14:48
I was trying to copy the settings of a HUE ledstrip to a RGB mysensor node and made a script to convert the values
In the end I don't need this but thought the script might be usefull to someone?
Later I will post the entire project of how to copy the settings of a HUE led strip to an mysensor node with RGB ledstrip attached
This will be based on an ESP12 unit with a cheap 12V RGB ledstrip
The HUE led strip I copy is called HueStrip and had ID 6 on the HUE bridge in this script
The script reads the settings of a selected HUE ID on the bridge when the status is changed according to domoticz
The script can return the following color formats
Hue/brightness/saturation
HSV
HSV (in domoticz format)
RGB
RGB(hex)
HSV
RGB
RGB(hex)
PRINT_MODE = false -- when true wil print output to log and send notifications
STORE = false --when true will store the calculated values as uservariables
if (devicechanged['HueStrip']) then
if PRINT_MODE == true then
print('strip changed')
if (otherdevices['HueStrip'] == 'Off') then
print('strip off')
print('strip on, collecting settings')
-- fixed values
base_url = 'http://HUE_Bridge_IP/api/HUE_Username' -- hue URL and username
domoticz_url = 'http://Domoticz_server_IP:Domoticz_server_Port' --URL of domoticz server
HUE_Strip_ID = 6 -- HUE ID on the HUE bridge of deviced to be replicated
-- Only load libaries now
http = require('socket.http')
ltn12 = require('ltn12')
json = require('json')
-- set some local variables
device = ''
mode = 'GET'
params = ''
function hueit(device, operation, mode)
local t = {}
local url = base_url .. device
local req_body = operation
print(url)
print(req_body)
local headers = {
["Content-Type"] = "application/json";
["Content-Length"] = #req_body;
client, code, headers, status = http.request{url=url, headers=headers, source=ltn12.source.string(req_body), sink = ltn12.sink.table(t), method=mode}
print(status)
return t
function processJSON(t)
obj, pos, err = json:decode(table.concat(t),1,nil)
print(table.concat(t))
print("check for error")
if err then
print ("Error for HUE Bridge:", err)
print("no error")
data = ''
i=HUE_Strip_ID
state=obj.lights[tostring(i)].state
dataHSV = data .. state.bri ..'|'.. state.hue ..'|'.. state.sat
dataXY = data .. state.xy[1] ..'|'.. state.xy[2]
print('Hue ID checked: ' .. i)
print('HSV: ' .. dataHSV)
print('XY: ' .. dataXY)
print('length of encode '..#dataHSV + #dataXY)
-- convert HUE values to RGB (hex)
H=(state.hue/65536)
S=(state.sat/256)
V=(state.bri/256)
-- convert HUE values to Domoticz values
Hdom=math.floor(H*360)
Sdom=math.floor(S*100)
Vdom=math.floor(V*100)
if Hdom == 239 then Hdom=Hdom+1 end -- some correction for rounding issues in domoticz
if Sdom== 99 then Sdom=Sdom+1 end -- some correction for rounding issues in domoticz
if Vdom== 99 then Vdom=Vdom+1 end -- some correction for rounding issues in domoticz
if STORE == true then
-- store HUE and RGB values in variables
commandArray['Variable:Led_HUE'] = tostring(stuffHSV)
commandArray['Variable:Hue'] = tostring(Hdom)
commandArray['Variable:Sat'] = tostring(Sdom)
commandArray['Variable:Bri'] = tostring(Vdom)
print('Hdom: ' .. Hdom)
print('Sdom: ' .. Sdom)
print('Vdom: ' .. Vdom)
-- convert HSV to RGB and RGB hex values
R, G, B =HSVtoRGB(H, S, V)
if R >= 16 then
Rhex=num2hex(R)
Rhex='0'.. num2hex(R)
if G >= 16 then
Ghex=num2hex(G)
Ghex='0'.. num2hex(G)
if B >= 16 then
Bhex=num2hex(B)
Bhex='0'.. num2hex(B)
RGB= R ..'|'.. G ..'|'.. B
RGBhex= Rhex ..''.. Ghex ..''.. Bhex
print('Hue: ' .. state.hue)
print('Sat: ' .. state.sat)
print('Bright: ' .. state.bri)
print('H: ' .. H)
print('S: ' .. S)
print('V: ' .. V)
print('R: ' .. R)
print('G: ' .. G)
print('B: ' .. B)
print('RGB: ' .. RGB)
print('Rhex: ' .. Rhex)
print('Ghex: ' .. Ghex)
print('Bhex: ' .. Bhex)
print('RGBhex: ' .. RGBhex)
commandArray['Variable:Led_Red'] = tostring(Rhex)
commandArray['Variable:Led_Green'] = tostring(Ghex)
commandArray['Variable:Led_Blue'] = tostring(Bhex)
return
function HSVtoRGB(h, s, v)
local r, g, b
local R1, G1, B1
local i = h * 6
local f = h * 6 - i
local p = v * (1 - s)
local q = v * (1 - f * s)
local t = v * (1 - (1 - f) * s)
i = i % 6
if i == 0 then r, g, b = v, t, p
elseif i > 0 and i <= 1 then r, g, b = q, v, p
elseif i > 1 and i <= 2 then r, g, b = p, v, t
elseif i > 2 and i <= 3 then r, g, b = p, q, v
elseif i > 3 and i <= 4 then r, g, b = t, p, v
elseif i > 4 and i <= 5 then r, g, b = v, p, q
R1 = math.floor(r * 255)
G1 = math.floor(g * 255)
B1 = math.floor(b * 255)
return R1, G1, B1
function num2hex(num)
local hexstr = '0123456789abcdef'
local s = ''
while num > 0 do
local mod = math.fmod(num, 16)
s = string.sub(hexstr, mod+1, mod+1) .. s
num = math.floor(num / 16)
if s == '' then s = '0' end
return s
t = hueit(device, params, mode)
processJSON(t)
