Hi all
I see there is a bunch of new firmwares out for the RFXTRX series of devices.
I have a RFXTRX433E.
There are 2 firmware's RFXTRX EXT and RFXTRX EXT2.
http://www.rfxcom.com/epages/78165469.s ... /Downloads
Is the EXT2 for a new hardware model?
I would normally use the RFXTRX433 EXT firmware, but the EXT2 has me wondering.
UPDATE** Check chapter 2 of the manual for an update on this - EXT supports some protocol EXT doesn't and visa versa.
Cheers
New firmware
stuiow
- Domoticz version: 3.6857
New firmware
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
b_weijenberg
- Target OS: -
Re: New firmware
Ext2 can be used in the RFXtrx433E.
See chapter 2 in the RFXtrx User Guide for the list of devices supported by each firmware version.
RFX-433, RFX-433EMC, RFX-868
joostvanderlinde
- Domoticz version: 2023.2
Re: New firmware
I bought the Promax set from Action. Ext2 is needed for that, it uses the "IT" protocol.
I upgraded RFXCom firmware via the windows RFXflash tool. Went well.
But in Domoticz I cannot see/check the "IT" protocol.
(BTW The Domoticz firmwareupgrade page only entions "Ext" btw (and not "EXT2"))
Is the "EXT2" firmware supported in Domoticx??
Running Domoticz V3.4834
Domoticz on BPI-M2-Pro (compiled on Ubuntu 22.04) and RPI (binary on Raspian 10)
RFXCom, Sonoff Zigbee stick, eBusd Adapter 5, P1, S0, Husdata H60 integration
Zigbee2MQTT AD, MQTT local, AirconWithMe, Ebusd, VolvoRecharge, PSA Car Controller
joostvanderlinde
Re: New firmware
mmm, nevermind.
Looks like Domoticz just works when just AC/ARC is checked.
The promax is recognized as Lighting2 / AC (at least the remote is).
