Lua Time scripts
CronoS
Lua Time scripts
Post by CronoS »
A quick question. I am building my first Lua script for my Lux sensor, the script is running fine so far. It does what I wanted to do. But I now I want to do something which involves time .
I have created a time script. Basically when the scripts executes, I want to place the current OS time in a user variabele, preferable in the format HH:MM.. Now, when the script executes again (one minute further); I want to read the user variabele, calculate the new time and I want to calculate the difference on both the times in minutes. If the result is 10 minutes or more, for example, then I want to do something in the script.
I like to use this time setting on my Lux sensor / lua script. If the lux sensor goes down because of a cloud, I don't want that Domoticz will close my sunscreen immediately because of the low lux.. I want to evaluate the Lux sensor 10 times or so before I close my sunscreen outside. At this stage I am able to evaluate the sensor ten times before it closes, but I want to time frame it basically.
I know how the variables works, but I really don't get the time settings in Lua. I simply don't get the format and how to calculate with it. I was able to get a String value in HH:MM and place this in a variable, but then I don't know how to calculate the difference because it is a string?
Can someone give me a push in the right direction, because I don't see it :)
Dnpwwo
Re: Lua Time scripts
Post by Dnpwwo »
Check the wiki, its got lots of useful stuff http://www.domoticz.com/wiki/LUA_comman ... difference
I wouldn't use a string, just work off the number of seconds otherwise you have to handle special cases around midnight and the like.
And do something like:
waitTime = 300           -- 5 minutes, time to leave devices on without movement
for deviceName,deviceValue in pairs(otherdevices) do
    if (timedifference(otherdevices_lastupdate[deviceName]) > waitTime) then
    	-- do stuff
CronoS
Post by CronoS »
I have seen all the wiki's, but I still don't get it :) I have placed this in the script:
waitTime = 300
if (timedifference(uservariables_lastupdate[Lux_schakelaar]) >  waitTime) then
	print ("Groter dan 5")
But I get an error that timedifference is zero .. so that didn't work ?
In you're example; you placed a loop with Do.. I guess I don't need that? I want to evaluate variables immediately basically?
Dnpwwo
Post by Dnpwwo »
Well you need to include the timedifference function in your script:
function timedifference (s)
  ret = os.difftime (os.time(), os.time{year=string.sub(s, 1, 4), month=string.sub(s, 6, 7), day=string.sub(s, 9, 10), hour=string.sub(s, 12, 13), min=string.sub(s, 15, 16), sec=string.sub(s, 18, 19)})  return ret
CronoS
Post by CronoS »
Thanks for the effort.. I am getting there.. :)
I have placed the function in top of the Lua script
Now I got this error on line 4, which is the function line:
4: bad argument #1 to 'sub' (string expected, got nil)
Was I able to copy you're code in the script ?
Dnpwwo
Post by Dnpwwo »
You were.
This error means that the value 'nil' was passed into the function which means that:
returned 'nil' (which means 'not found' in this case). if Lux_schakelaar is the name of your device you need to use
uservariables_lastupdate["Lux_schakelaar"]
CronoS
Post by CronoS »
Thanks ... It was indeed this typo :) Still can't translate this function, but it works :) I have more tries and testing this weekend, but my script seems to work OK for now :)
dannybloe
Post by dannybloe »
<shameless-plug>
Or you use this: dzVents :mrgreen:
It does all the nasty time stuff for you. Couple of lines of code and your done.
</shameless-plug>
