Database conversion to latest Domoticz version
ARichter
Hallo,
I am Andreas and using the Domoticz version 1.0.10. on a Raspberry Pi since a long time without any problems. To update the system I would like to install now the newest version of Domoticz.
My question is:
Is it possible to convert the old database including my settings and all information about switches, blinds,... to the database of the latest Domoticz version or did I have to input all old information manually.
Thank you for your support
Andreas
My question is:
Andreas
ARichter
Re: Database conversion to latest Domoticz version
Thank you for your quick reply.
The old version has no update function in the menu, so I have to install the new version but copying the old database (domoticz.db) to the new version does not show any settings.
- gizmocuz
The database will be automatically converted to the latest
But make sure you make a complete backup of the domoticz folder so you can always go back
ARichter
Please let me know how I can update this old version because the command ./updaterelease does not work.
Thank you for your help.
- gizmocuz
Why, what is the output ?
ARichter
The respond is: command not found
- gizmocuz
please follow the wiki how to install the stable (perform the same action to update)
http://www.domoticz.com/wiki/Installing ... spberry_PI
ARichter
Sorry but this fails. It seems that it overwrites the database and when the program starts it will only show the setup menu.
ARichter
You are right the files is still there but how can I load the data in the program?
- gizmocuz
Just start the program
