lanbox dmx controller
Posted: Sunday 28 February 2016 12:35
some example code, to control 4 DMX RGB panels connected to a Lanbox
requires luasocket library
local socket = require("socket")
function SendCommand (address,port,commandstring)
local switchto16bitcommand = "*65ff#"; -- Common16BitMode On
local step = 0;
local tcp = assert(socket.tcp())
tcp:connect(address, port);
tcp:settimeout(0)
tcp:setoption("tcp-nodelay",true)
tcp:setoption("keepalive",true)
local t1 = os.time()
while true do -- wait until command done
if (os.difftime (os.time(),t1) > 5) then
print ("LanBox Timeout")
break
local s, status, partial = tcp:receive()
if status == "closed" or status == "Socket is not connected" then
break
local data = s or partial
if (data) and (data ~= "") then
print ("&"..data);
if string.find (data,"?",1,1) ~= nil then
print ("LanBox Error Received")
break
elseif string.find (data,">",1,1) ~= nil then
if (step ==0) then
print (commandstring);
tcp:send(commandstring);
step=1;
elseif (step==1) then
break
elseif string.find (data,":",1,1) ~= nil then -- 'enter password :'
tcp:send('777\r');
elseif string.find (data,"d",1,1) ~= nil then -- 'connected'
print (switchto16bitcommand);
tcp:send(switchto16bitcommand);
tcp:close()
function StartCue (address,port,cuenumber)
local commandstring = "*5601"..string.format("%04X",cuenumber).."01#"; -- EngineGo Eng# Cuelist cuestep
function SetRGBColor (address,port,R,G,B)
local commandstring = ""
commandstring = "*C901"; -- ChannelSetData Eng# Ch# (R) Chval (R)
-- 1,14,27,40 control byte for 4 panels
-- 2 -13 RGB panel #1
-- 15-26 RGB panel #2
-- 28-39 RGB panel #3
-- 41-52 RGB panel #4
for i = 0,3 do
commandstring = commandstring..string.format("%04X",i*13+1).."FF";
for j = 0,3 do
commandstring = commandstring .. string.format("%04X",i*13+j*3+2) .. string.format("%02X",R);
commandstring = commandstring .. string.format("%04X",i*13+j*3+3) .. string.format("%02X",G);
commandstring = commandstring .. string.format("%04X",i*13+j*3+4) .. string.format("%02X",B);
commandstring = commandstring.."#";
SetRGBColor ("192.168.2.77",777,255,0,0)
StartCue ("192.168.2.77",777,40)
