Adjustement Temperature wemos + DTH22 Topic is solved
Qcvictor
Post by Qcvictor »
I use wemos D1 mini with her dht22 shield, everything work as expected, but position shield just above the ESP give me 3 degre offset, so I want use the adjustment for operate correction, unfortunately when I apply this adjustment nothing happen!
simonrg
Domoticz version: 3.8807
Re: Adjustement Temperature wemos + DTH22
Post by simonrg »
You don't say which ESP8266 firmware you are using on your Wemos D1 Mini.
Assuming you are using the ESPeasy firmware, then under Devices / DHT22 edit - in the formula box enter:
if 3 degrees too high then:
%value%-3.0
if 3 degrees too low then:
%value%+3.0
I have just got 4 DHT22 sensors, I have attached them to one Wemos D1 Mini and I am sending all 4 values back to Domoticz, just playing with offsets to understand how accurate / reproducible the measurements are.
ESPeasy is well documented here: http://www.esp8266.nu/index.php/HumiditySensor
Qcvictor
Post by Qcvictor »
many tanks simonrg, exactly what I looking for :mrgreen: you are right ESP Easy R78
My offset : -3.5 for temperature and + 5 for humidity, did you have something similar?
