USB on RFLink not working after Reboot (Raspberry pi)
Posted: Tuesday 23 February 2016 16:34
by poke81
i'm from Germany. I have an big Problem with my RFLink Gateway (Arduino Mega from nodo.nl) The Problem is that when i reboot my RasberryPI then are no communication between the Domoticz and RFLink Gateway.
I have read the Wiki i i have all about set up in the pages describe. Wenn ich after Reboot den Arduino relug in the same usb port all is find an i can switch my devices on.
But after Reboot the The Device in Domitcz ist shown but ich cannot send any command to rflink. The ttyUSB port is show correct in domoticz even after reboot but only commands can be send when i replug the arduino mega (whitch has RFLink connected.
What can i do ?
Marcel
Re: USB on RFLink not working after Reboot (Raspberry pi)
Posted: Thursday 25 February 2016 12:45
by Stuntteam
Posted: Monday 07 March 2016 9:49
by poke81
Hello Stuntteam,
sorry for my late Answer. Yes i have Read ans set the PersistantUSB Devices.
This ist my output from lsusb:
root@domoticz:~# lsusb -v | more
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 2 TT per port
bMaxPacketSize0 64
idVendor 0x0424 Standard Microsystems Corp.
idProduct 0x9514
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 1 Single TT
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 2 TT per port
iInterface 0
bLength 7
bDescriptorType 5
--More--
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 5
wHubCharacteristic 0x000d
Per-port power switching
Compound device
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 1 milli Ampere
DeviceRemovable 0x02
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Port 2: 0000.0100 power
Port 3: 0000.0103 power enable connect
Port 4: 0000.0100 power
Port 5: 0000.0100 power
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 4.01
iManufacturer 3 Linux 4.1.13+ dwc_otg_hcd
iProduct 2 DWC OTG Controller
iSerial 1 20980000.usb
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
--More--
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0008
Ganged power switching
bPwrOn2PwrGood 1 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x00
Hub Port Status:
Self Powered
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idProduct 0xec00
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
iConfiguration 0
--More--
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceProtocol 255
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 4
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
Self Powered
Bus 001 Device 005: ID 2341:0042 Arduino SA Mega 2560 R3 (CDC ACM)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 2 Communications
--More--
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x2341 Arduino SA
idProduct 0x0042 Mega 2560 R3 (CDC ACM)
bcdDevice 0.01
iManufacturer 1 Arduino (www.arduino.cc)
iProduct 2
iSerial 220 954323132383511191F1
bLength 9
bDescriptorType 2
wTotalLength 62
bNumInterfaces 2
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
CDC Header:
bcdCDC 10.01
CDC ACM:
bmCapabilities 0x06
sends break
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 255
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
iInterface 0
bLength 7
bDescriptorType 5
--More--
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
Device Status: 0x0000
(Bus Powered)
root@domoticz:~#
root@domoticz:~#
and This ist my 99-usb-serial.rules file:
Datei: /etc/udev/rules.d/99-usb-serial.rules
SUBSYSTEM=="tty", ATTRS{idVendor}=="2341",
ATTRS{idProduct}=="0042", ATTRS{serial}=="954323132383511191F1",
SYMLINK+="ttyUSB-RFX433"
have i set a wrong value ? The Problem is only when my PI is booting with USB pliugged in. After Boot i replug my arduino an then all is fine in domoticz.
please can you help me.
Thx
Marcel
Posted: Friday 27 March 2020 17:18
by THEND
Hello. I have the same problem Domoticz ver. 2020.1. Did you solve it?
Posted: Tuesday 14 July 2020 21:58
by mpx2
When I updated to 2020.1 RFLink stopped working. I abandoned Domoticz because all I have had is problems.
Now I had some time and I updated Domoticz to version 2020.2 (build 12211) and I got RFLink working.
Posted: Tuesday 14 July 2020 22:32
by waaren
mpx2 wrote: Tuesday 14 July 2020 21:58
Did you make the USB ports persistent ? See
this wiki page
