Virtual switch "On delay" doesn't work
olleman
Post by olleman »
I have a PT2262 door switch, cheap from eBay, which only sends OFF/ON command when the door is opened (ON/OFF depending on how it's configured).
I had, until recently, this switch configured as Lighting 4 device that sent "ON" signals each time the door was opened. I used an "Off delay" to have it automaticly closed again after 2 seconds. This is needed for the logic of my alarm system.
Since Firmware 251 för the RFXCom receiever the device is instead recognized as Lighting 5 and now gets "OFF" signals. I did the same thing but used an "ON" delay instead. But this won't work. I have readded the switch a number of times but no matter what I do it won't turn "ON" after 2 seconds. I have also tried solving this with an Event but that doesn't work either. I can however manually turn the switch "ON".
For now I've had to create a virtual switch to get a door switch that opens and then closes again but I would like to have this issue resolved.
Does anyone have any thoghts on this?
Regards, Olle
la0fd
Re: Virtual switch "On delay" doesn't work
Post by la0fd »
It must be a bug! It doesn't work here either.
