Hello
Just two questions about Philio PAN04-1B DOUBLE SWITCH. If any Domoticz user has this device he could answer them
1. Does this device report status for each relay when swtiched manually? I mean if they send status when you switch on/off with Wall switch, not from domoticz. Of course: without poll.
Documentation says it sends status of every relay: Relay 1&2 group1, relay1 group2, and relay 3 to group3, but older Philio PAN-04(with the same characterisitcs) doesn do so. (or Domoticz can not read them)
2. Is it posible to switch each relay independently from domoticz and manually?
I've read that it's not possible to do so, but I have doubts.
Philio PAN04-1b
- Domosapiens
- Domoticz version: V3.5981
Re: Philio PAN04-1b
I assume that the PAN04-1B has the same functionality as the PAN04-1A (only more power)
Have you seen this post ? Z-Wave fact file: Philio PAN04-1 (not PAN04-1B)
1) no experience, but feedback should work if you connect your controller under Node Management / Groups and Network, with Group 1 and Group 2 (Group 3 is for both relays)
2) Yes both relays separate and both combined can be controlled. Domoticz gives you 3 switches: 1, 2 and 1&2 combined
juankar
- Domoticz version: 4.
Re: Philio PAN04-1b
Thanks Domosapiens for your reply
Yes, I have a PAN04-1 (not 1A nor 1B) and if no polling no status of individual relays when switched manually. Of course every group is associated to node 1 (controller). I need poll or a workaround to update status when manual switching (that is my solution). Any manually activated relay just reports an ALL RELAY activated (group 3). I think it's an issue of Domoticz or OZwave, because when I refresh on OZW Control Panel status are set OK.
And, about individual control of relays, this is reasonable, as I thought the info I had read must to be wrong.
I'm between Philio and Qubino+, this is smaller and, I think, better quality but it seems there is some issues with Domoticz.
Thanks again
Thanks again
juankar
Re: Philio PAN04-1b
I resend my question about Philio04-1b (1B is the model I can buy):
Does it send report status to Domoticz? (when manually switched)
Can you control every relay (not both at the same time)?
Power are reported fine?
And Domoticz shows two or three switches?
I want total security, I've bought Qubino because I thought it worked fine and.... it doesn't work right (there is a big fault in power reports)
