Page 1 of 2
Sensative strips
Posted: Saturday 20 February 2016 14:04
by Gabe
Hi everybody
I bought the sensative strips, but it looks Domoticz non support it.
I can inclusde it in Domoticz, but under Hardware I found follow:
Unknown: id=019a Unknown: type=0003, id=0003
Unfortunately the strip will also not give the status to the controller.
Can anybody help me?
Thx
Re: Sensative strips
Posted: Saturday 20 February 2016 14:07
by gizmocuz
Is this mysensors or zwave ?
Please post a link to the manual/shop
Posted: Saturday 20 February 2016 14:09
by Gabe
Posted: Saturday 20 February 2016 14:10
by gizmocuz
Then you posted in the wrong forum section, this is for "MySensors.org"
Moving this topic
Does the node send an On or Off ? (it does not matter if it is not correctly recognized)
Posted: Saturday 20 February 2016 14:16
by gizmocuz
Also please state your domoticz version, as i see in the beta version it is available
updating to the beta, then excluding the node, and including it again should get you there
Posted: Saturday 20 February 2016 14:21
by Gabe
Sorry
no no on or off
Ihave the last stable version how i can update to beta?
Posted: Saturday 20 February 2016 15:20
by Gabe
Ok withnthe beta he show it but the status of the device not change.
Any idea?
By the way when I could back to the stable version?
Posted: Saturday 20 February 2016 19:25
by Gabe
now I found the device after reseting all is good
Thx for helping
Posted: Friday 04 March 2016 22:07
by Mozart
I'm interested in this strip, could you tel me what kind of zwave controller you use?
I'm using a aeotec stick, not z-wave plus but normal z-wave.
Posted: Wednesday 27 April 2016 12:13
by Gabe
I use zwave me stick and it function well
Posted: Sunday 02 October 2016 10:48
by kondik
I have bought the Sensative Strips (
http://www.sensative.com/strips.html) and unfortunately it doesn't work with Domoticz
When I add Strips to my Z-wave network then I see in Domoticz as "unknown" (ID 0x0000; Type 0x0000).
I have tested with different version of Domoticz, i.e. v3.5700 (the newest beta version) and v3.4834 (the newest stable version). For both I have "unknown".
Could you provide me the valid version of Domoticz with Sensative Strips is working fine or some instruction what should I do in order to Strips will work.
Thanks in advance,
Regards,
Konrad
Posted: Sunday 02 October 2016 15:23
by Domosapiens
Konrad
I think it is this one in the manufacturer_specific.xml
<Manufacturer id="019a" name="Sensative">
<Product type="0003" id="0003" name="Strips" config="sensative/strips.xml" />
There is a file in /Config/sensative/strips.xml
With (ID 0x0000; Type 0x0000), I think the inclusion went wrong
- Picture your Node list.
- Catch that part from your zwcfg_0xzzzzzzz.xml file and show as Code insert
Posted: Sunday 02 October 2016 17:06
by kondik
Below the part my zwcfg_0xzzzzzzz.xml file as you asked:
<Node id="5" name="" location="" basic="4" generic="7" specific="1" type="Notification Sensor" listening="false" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Probe">
<Manufacturer id="0" name="">
<Product type="0" id="0" name="" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1">
<Instance index="1" />
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false"
poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
<CommandClass id="132" name="COMMAND_CLASS_WAKE_UP" version="1" request_flags="2">
<Value type="int" genre="system" instance="1" index="0" label="Wake-up Interval" units="Seconds" read_only="false" write_only="false" verif
y_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="3600" />
</CommandClass>
</CommandClasses>
</Node>
Posted: Sunday 02 October 2016 23:00
by Domosapiens
Ok.
Remove this part from zwcfg_0xzzzzzzz.xml
Make sure the device is awaken
Restart OpenZwave (disable/enable your stick)
Catch the log from Domoticz
Posted: Thursday 06 October 2016 20:11
by kondik
Thank you very much - it helps me.
Now I see: "Sensative AB Strips-MAZW".
Posted: Thursday 06 October 2016 22:39
by Clemen
both my strips is not working more after under 6months seems that the non changeable battery is dead.. Anyone seeing this behaviour?
Posted: Friday 14 October 2016 9:46
by kimhav
Clemen wrote:both my strips is not working more after under 6months seems that the non changeable battery is dead.. Anyone seeing this behaviour?
Interesting, I was ready to place an order for couple of these but if they die that fast it's a no-show then for me. Remember that they say that the battery should least for several years. Also, is it really impossible to change the battery! What a waste then!! What are Sensative saying?
Posted: Friday 14 October 2016 18:19
by juankar
In the web I read
"Up to 10 year battery life - no more changing batteries"
Which is the awake interval in the config? If you set 30 min battery life is shorter (but 6 months is a very short time), but if you have set 24 hours (default) this could be a fault of the device.
Posted: Saturday 15 October 2016 11:33
by Clemen
wake time was set to 24h. the one strip was a door, which are opened multiple times a day, this one died first the second on a window died a few months after.
Posted: Sunday 22 October 2017 12:27
by heistje
I have also one installed on a door but I don't get it to work...
Inclusion works, pops up in the "Node list", but impossible to let it work.
Tried to change the "Notification Type" but without result, it remains on "Notification Report" (also after waking up the strip with the magnet), not sure changing the report tupe would do anything...
communication seems not be working.
Anyone who has this device working?
Thx!
