Script to import CumulusMX Data from an http call
Posted: Friday 19 February 2016 19:00
I have a weather station sitting on an old Raspberry Pi B running CumulusMX.
The following call returns all the output data:
Quite a lot of information:
I have written the following code to update a few idxs: (first go at lua and not pretty!)
If anyone is interested I would be pleased for some help improving this.
What are the humidity and weather devices looking for in the 0 place holders?
I know the file handling is poor and there must be a better way of loading the t[] array given the nature of the data.
All advice much appreciated.
TXs to the author of the weather Underground parser for many ideas.
http://<ip>:8998/api/data/currentdataQuite a lot of information:
{"AlltimeHighPressure":"1043.6","AlltimeLowPressure":"981.0","AppTemp":"2.8","AvgTempToday":3.9326086956521555,"Avgbearing":140,"Bearing":180,"BearingRangeFrom10":130,"BearingRangeTo10":180,"Build":"3036","Cloudbase":496,"CloudbaseUnit":"ft","CurrentSolarMax":0,"DataStopped":false,"DominantWindDirection":"SE","Forecast":"Showery, becoming less settled","HeatIndex":"7.3","HighAppTempToday":"4.6","HighAppTempTodayTime":"12:26","HighBeaufortToday":"F3","HighDewpointToday":"6.1","HighDewpointTodayTime":"17:32","HighGustBearingToday":135,"HighGustToday":"16","HighGustTodayTime":"17:35","HighHeatIndexToday":"9.0","HighHeatIndexTodayTime":"12:25","HighHourlyRainToday":"0.0","HighHourlyRainTodayTime":"00:06","HighHumToday":92,"HighHumTodayTime":"09:06","HighPressToday":"1024.3","HighPressTodayTime":"00:56","HighRainRateToday":"0.0","HighRainRateTodayTime":"00:06","HighSolarRadToday":0,"HighSolarRadTodayTime":"00:06","HighTempToday":"9.0","HighTempTodayTime":"12:25","HighUVindexToday":"0.0","HighUVindexTodayTime":"00:06","HighWindToday":"12","Humidex":"7.0","IndoorHum":68,"IndoorTemp":"12.5","LastDataRead":"17:42:59","LastRainTipISO":"2016-02-17 14:38","LowAppTempToday":"-2.8","LowAppTempTodayTime":"06:16","LowDewpointToday":"-2.2","LowDewpointTodayTime":"04:46","LowHumToday":71,"LowHumTodayTime":"12:26","LowPressToday":"1014.2","LowPressTodayTime":"17:18","LowTempToday":"0.4","LowTempTodayTime":"04:46","LowWindChillToday":"-1.3","LowWindChillTodayTime":"06:16","Moonrise":"14:21","Moonset":"05:09","OutdoorDewpoint":"6.1","OutdoorHum":92,"OutdoorTemp":"7.3","PressTrend":"-1.2","PressUnit":"mb","Pressure":"1014.4","RainLastHour":"0.0","RainMonth":"57.3","RainRate":"0.0","RainToday":"0.0","RainUnit":"mm","RainYear":"125.1","RainYesterday":"0.0","Recentmaxgust":"16","SolarRad":0,"StormRain":"0.0","StormRainStart":"-----","Sunrise":"07:19","Sunset":"17:31","SunshineHours":"0.0","TempTrend":"-0.1","TempUnit":"°C","UVindex":"0.0","Version":"3.0.0","WindAverage":"11","WindChill":"4.1","WindLatest":"12","WindRoseData":"0,0,46,0,712,1061,10336,521,4638,0,220,1,0,0,0,0","WindRunToday":"100.4","WindUnit":"mph"}Code: Select all
print("Load CMX data ".._VERSION.."=".."!\n")
local idxthp = 32 --idx of the virtual sensor you need to change this to your own Device IDx
local idxt = 30
local idxh = 31
--if devicechanged[sensorwu] then
if true then
-- create file of values from CumulusMX (Change IP address to suit your system)
os.execute('curl "http://<ip>:8998/api/data/currentdata" > /home/pi/CMX.txt')
-- one long line
for line in io.lines("/home/pi/CMX.txt") do
t = {}
s = line
-- find value pairs on pattern match
for k, v in string.gmatch(s, '(%w+)":"(%w+)') do
-- Load array of values keyed by the value name
t[k] = v
-- undo rem line below to print all values to the log
-- print(k.."="..v)
for k, v in string.gmatch(s, '(%w+)":(%w+)') do
t[k] = v
-- print(k.."="..v)
varstr="WindRunToday"
--print(varstr.."="..t[varstr].."miles")
--TEMP;HUM;HUM_STAT;BAR;BAR_FOR
IndoorTemp=t["IndoorTemp"]
IndoorHum=t["IndoorHum"]
Pressure=t["Pressure"]
PressTrend=t["PressTrend"]
print(IndoorTemp,IndoorHum,Pressure,PressTrend)
commandArray[1] = {['UpdateDevice'] = idxt .. '|0|' .. IndoorTemp}
commandArray[2] = {['UpdateDevice'] = idxh .. '|' .. IndoorHum .. "|0" }
commandArray[3] = {['UpdateDevice'] = idxthp .. '|0|' .. IndoorTemp .. "|" .. IndoorHum .. "|0|" .. Pressure .. "|0" }
return commandArrayWhat are the humidity and weather devices looking for in the 0 place holders?
