FreeBSD 10.2 and Z-Stick Gen 5 (ZW090) don't work
Posted: Thursday 18 February 2016 18:15
by EricD
Good evening,
I have a problem with a Z-Stick Gen 5 (ZW090) which is not recognized under FreeBSD 10.2 per share against OpenZwave no worries with S2 Stick works perfectly.
Do you have a solution ?
Domoticz -> v2.4608
OpenZwave -> 1.4-53-g8c1073f
Thank you in advance.
error:
./MinOZW / Dev / cuaU0
Starting with MinOZW OpenZWave Version 1.4.53
2016-02-18 19: 11: 46.434 Error, Can not find a path to the configuration files at ../../../config/, Using config / INSTEAD ...
2016-02-18 19: 11: 46,440 Information, Reading config / options.xml for Options
2016-02-18 19: 11: 46,443 Information, Reading options.xml for Options
2016-02-18 19: 11: 46,447 Always, OpenZwave Version 1.4.53 Starting Up
2016-02-18 19: 11: 46,449 Info, Setting Up Network Provided Key for Secure Communications
2016-02-18 19: 11: 46,450 Warning, Failed - Network Key Not Set
2016-02-18 19: 11: 46.452 Info, mgr, Added driver for controller / dev / cuaU0
2016-02-18 19: 11: 46,453 Info, Opening controller / dev / cuaU0
2016-02-18 19: 11: 46.455 Info, Trying to open serial port / dev / cuaU0 (Attempt 1)
2016-02-18 19: 11: 46,457 Information, Serial port / dev / cuaU0 ouvert (Attempt 1)
2016-02-18 19: 11: 46,460 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xE9
2016-02-18 19: 11: 46,461 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-02-18 19: 11: 46,462 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-02-18 19: 11: 46,463 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xFB
2016-02-18 19: 11: 46,464 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2016-02-18 19: 11: 46,465 Detail,
2016-02-18 19: 11: 46,466 Info, contrlr, Sending (Command) Message (Callback ID = 0x00, 0x15 = Expected Reply) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xE9
2016-02-18 19: 11: 47,475 Error, contrlr, ERROR: Dropping command, after-expected response not received 1 Attempt (s)
2016-02-18 19: 11: 47,475 Detail, contrlr, current Removing Message
2016-02-18 19: 11: 47.476 Detail, contrlr, Notification: Notification - TimeOut
2016-02-18 19: 11: 47.476 Info, contrlr, Sending (Command) Message (Callback ID = 0x00, 0x20 = Expected Reply) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-02-18 19: 11: 48.477 Error, contrlr, ERROR: Dropping command, after-expected response not received 1 Attempt (s)
2016-02-18 19: 11: 48,478 Detail, contrlr, current Removing Message
2016-02-18 19: 11: 48,478 Detail, contrlr, Notification: Notification - TimeOut
2016-02-18 19: 11: 48,479 Info, contrlr, Sending (Command) Message (Callback ID = 0x00, 0x05 = Expected Reply) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-02-18 19: 11: 49,481 Error, contrlr, ERROR: Dropping command, after-expected response not received 1 Attempt (s)
2016-02-18 19: 11: 49,481 Detail, contrlr, current Removing Message
2016-02-18 19: 11: 49,482 Detail, contrlr, Notification: Notification - TimeOut
2016-02-18 19: 11: 49,482 Info, contrlr, Sending (Command) Message (Callback ID = 0x00, 0x07 = Expected Reply) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xFB
Re: FreeBSD 10.2 and Z-Stick Gen 5 (ZW090) don't work
Posted: Thursday 18 February 2016 18:27
by gizmocuz
I think its best if you make a post on the openzwave forum, as this is not domoticz related (as i see you also have this with miniOZW)
