I am new here by VERY impressed with what I see!
I use a UDI ISY aoutomation controller, which has 100% support for Insteon, zWave, Echo and many additional devices controllers via "Network Recourses" IMO It is a much more robust/reliable devise along the lines of Vera.
It does not seem there is yet integration between the ISY and Domoticz. There should be . Below is a post I made on the ISY forum telling users about Demotics and its interface with MySensors. I would encourage you to look at the ISY and think about integration with Demoticz. Ive suggested the same to the ISY crowd.
http://forum.universal-devices.com/topi ... /?p=167437
https://www.universal-devices.com/resid ... zw-series/
Thanks!!
Universal Devises ISY Integration: A Powerful Controller: Insteon/zWave/Echo/Energy/Network??
sea3pea0
Re: Universal Devises ISY Integration: A Powerful Controller: Insteon/zWave/Echo/Energy/Network??
+1 for integration with ISY, I am a little surprised there isn't any integration yet. I have been manually integrating some functions between the two.
Currently I have a couple of thermostats reporting temperature and humidity to virtual sensors in domoticz via isy programs that call php scripts on my NAS. I would have just had the isy report the temperature and humidity directly to domoticz but since domoticz expects celcius values, I had the isy call a php script located on the webserver that my nas is running to convert the Fahrenheit temperature values to Celsius before updating domoticz via curl from the same php script.
I also have a few on/off switches set up in domoticz with their on/off actions directed to the isy's rest interface.
Working with both controllers seems a bit cumbersome and redundant but I found that domoticz provided an easy way to bridge the capabilities of the synology nas that it runs on with the isy controller. Also I really like the web gui of domoticz, very nicely designed.
Anyway, many thanks to the developers of domoticz and I patiently await further integration between the domoticz and the isy.
ccclapp
It sounds like you have a working but complex system. I echo your request for easier integration. We will see…
