How do I tell if Domoticz can see the RFXCom
Posted: Tuesday 16 February 2016 22:14
by tre4bax
Hi there,
My rfxcom seems to be connected on a tty port for USB0 but when I try to use it nothing happens. Is there a log somewhere that can tell me if Domoticz is able to talk to the RFXCom or whether the fault is internal? Essentially how do I debug a non functioning rfxcom.
Just to eliminate the device itself. I'm setting up a new linux instance to do this with. The RFXcomm works fine with the original Raspberry pi based installation.
Any ideas would really help.
Re: How do I tell if Domoticz can see the RFXCom
Posted: Wednesday 17 February 2016 8:55
by jannl
When you do a reboot, you should see the initialisation in the logfile
Posted: Sunday 21 February 2016 14:57
by tre4bax
Ta Jannl. Do you mean the Domoticz log file or a linux one?
Posted: Monday 11 April 2016 10:16
by starfish001
tre4bax wrote:Ta Jannl. Do you mean the Domoticz log file or a linux one?
both Domoticz log and dmesg from shell.
I would reboot look at dmesg for rfxcom and the port it is using then check hardware tab within GUI ( perhaps reset the procotolcs) - if you check the Domoticz log you will see the port being used and the proctocols set.
