Hello!
Anybody here using Domoticz with Synology adding two USB-devices via an USB-Hub? USB port1 is connected with external harddisk and I want to connect ZWave Me USB and maybe a RFXtrx433E via USB-Hub.
Is this a working environment? Or would you recommend to connect the RFXtrx433E to a Raspberry with own Domoticz and connect both server?
BR, Jens
Synology + RFXtrx433E + ZWave Me USB - USB-Hub
Valk
Re: Synology + RFXtrx433E + ZWave Me USB - USB-Hub
I use two USB-devices on a USB-Hub.
Synology DS215j, on one USB port Aeotec Z-Stick Gen5
On the other port a USB-Hub with a RFXtrx433E and a APC Back-UPS CS 350.
jmeyerdo
Hi!
Great - thank you for your helpful answer.
Now I only have to solve my general problems with USB-stick ZWave Me (not recognized by Synology properly):
BR, Jens
Feb 17 11:50:13 synology synousbmodemd: usbmodem_atif.cpp:114 Unknown vendor id 0658, assign default ATIF
Feb 17 11:50:14 synology synousbmodemd: usbmodem_devicenodehandler.cpp:277 No respond on modem cmd AT+CPIN?
Feb 17 11:50:14 synology synousbmodemd: usbmodem_simhandler.cpp:49 Warning: sim mute before handler init
Feb 17 11:50:14 synology synousbmodemd: usbmodem.cpp:471 failed on setup sim handler
Feb 17 11:50:14 synology synousbmodemd: usbmodem_list.cpp:105 Failed to init info [1002]Who is online
