Trail map- custom page
Posted: Saturday 13 February 2016 20:03
by qlin
Hey
I would like to build a custom page showing GPS track on map. This should work base no mqtt GPS data from smartphone (send by owntracks app).
I find interesting plugin http://leafletjs.com/ and try to use it base of example
<html>
<head>
  <title>A Leaflet map!</title>
   <link rel="stylesheet" href="http://cdn.leafletjs.com/leaflet-0.7.3/leaflet.css"/>
  <script src="http://cdn.leafletjs.com/leaflet-0.7.3/leaflet.js"></script>
  <style>
    #map{ height: 180% }
  </style>
</head>
<body>
  <div id="map"></div>
  <script>
  // initialize the map
  var map = L.map('map').setView([42.35, -71.08], 13);
  // load a tile layer
  L.tileLayer('http://tiles.mapc.org/basemap/{z}/{x}/{y}.png',
      attribution: 'Tiles by <a href="http://mapc.org">MAPC</a>, Data by <a href="http://mass.gov/mgis">MassGIS</a>',
      maxZoom: 17,
      minZoom: 9
    }).addTo(map);
  </script>
</body>
</html>
This example is working fine when i call
http://192.168.10.95:8181/map.html
or
http://192.168.10.95:8181/tempaltes/map.html
but not from domoticz user menu.
I received :
ReferenceError: L is not defined
where L is leaflet object.
I noticed that leafletjs link and script in this way are not call, so I moved both to www/index.html.
After that i don't received this error but map is not displayed.
Is there somebody to help me solve this problem?
Re: Trail map- custom page
Posted: Saturday 13 February 2016 20:58
by nayr
custom templates cant have a html, head, and body tags.. those are already provided.
check out the custom.example in the templates folder, and look at the javascript console for errors.
Since your page is local you can also try loading it in an iframe, this is all you need in your template:
<iframe frameborder="0" allowtransparency="true" src="/map.html" style="height: 95%; width: 100%; position: absolute; left: 0; top: 40px;"></iframe>
Posted: Monday 15 February 2016 0:06
by qlin
some problems run it base on index.html :oops: . Without any error on console but map doesn't appear.
So I used iframe followed your suggestion and now is working fine. Thanks a lot.
I think that it is better solve for me.
If somebody want try to use:
maps_v1.tar.gz
(48.37 KiB) Downloaded 145 times
Pls, copy contents to www/templates folder and use by user menu.
In next step I will try parse some data from database.
