Page 1 of 4
Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
Posted: Friday 12 February 2016 16:29
by kman
I am looking for a cheap(£10 or lesser) temperature & humidity sensor compatible with RFXCOM/Domoticz.
Any suggestions?
thanks!
Re: Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
Posted: Friday 12 February 2016 22:43
by markk
Posted: Saturday 13 February 2016 19:03
by kman
Posted: Saturday 13 February 2016 20:01
by kman
Cresta TX-320 doesn't seem to be available in the UK. Shipment costs from Netherlands, seems to cost euro 19.
I am back to square one, not being to find a cheap Temp/Hum sensor under £10
Posted: Saturday 13 February 2016 20:16
by Westcott
I got one from Banggood - it worked straight away with RFXtrx
http://www.banggood.com/433MHz-Wireless ... 8820141020
Posted: Saturday 13 February 2016 20:23
by kman
Super! thanks a lot Westcott!
Ordered two of them!
Posted: Sunday 14 February 2016 12:17
by simonrg
Looks good, one question - do they have fixed ids or does it change each time you replace the batteries?
I have 4 LaCrosse temperature / humidity sensors, which are great apart from resetting their ids each time the batteries are replaced meaning they are recognised as new devices in Domoticz each time the battery is replaced, meaning a old temperature sensor in Domoticz has be replaced by new device without loosing log and then renamed to original name so that scripts keep running
Other challenge is physics, the sensor I have outside needs its battery changing about every 4 weeks, whereas the sensor in the roof space lasts for about 1 year. I guess outside temperature changes very frequently so it transmits tempeartures far more often, hence running down the battery rapidly -
. And as I use rechargeable batteries they report as 100% and then suddenly fail.
Posted: Sunday 14 February 2016 12:40
by Westcott
I guess it's fixed. I would test it for you, but the case is well screwed together.
It reports every 34 secs.
I've had it for 6 weeks, the battery is still reporting 100%
Posted: Sunday 14 February 2016 12:43
by LouiS22
You know that you can simply replace the new device with the old one and keeping the logs as well? How? Read the manual,
http://www.domoticz.com/DomoticzManual.pdf, it's on page 20.
Also, these "cheap" sensors don't submit their battery levels. Guess you're expecting too much for that price
One more thing: you didn't specified but my guess is that your batteries are 1.2V ones, while the specs are for 1.5V. That would explain the sudden drop, as they're falling below the minimum expected V value.
Posted: Sunday 14 February 2016 13:23
by simonrg
LouiS22 wrote:You know that you can simply replace the new device with the old one and keeping the logs as well? How? Read the manual,
Thanks, I do just replace the old device with the new one, but it isn't a one step process unless I am missing something - I go to Settings / Accept New Devices for 5 Minutes, then Devices find the new sensor click the green arrow give the new device a dummy name, then Temperature page replace Old device with new device, then rename new device to old device name. Not difficult but not exactly smooth, hence keeping same id would be a real plus.
In terms of batteries, as you say I am hoping for too much for the price.
Posted: Sunday 14 February 2016 19:50
by simonrg
Just stumbled across a thread on the forum, that seems to say these sensors are of limted use as the temperature drifts -
http://domoticz.com/forum/viewtopic.php ... 3&start=20.
Posted: Sunday 14 February 2016 20:22
by Westcott
To be fair, the later posts in that thread seem to say that they are OK
Posted: Sunday 14 February 2016 22:04
by LouiS22
One more observation: I have three Crestas (I know, they're above the budget), but they're battery friendlies. Have them more than a year, reading is in every minute or so, and they're still with their original batteries (1.5V ones).
Posted: Sunday 14 February 2016 22:08
by LouiS22
simonrg wrote:LouiS22 wrote:You know that you can simply replace the new device with the old one and keeping the logs as well? How? Read the manual,
It's not that big deal, and if you're using 1.5V ones, you don't have to repeat the process that often.
Posted: Friday 19 February 2016 15:38
by planetf1
I just ordered
http://www.amazon.co.uk/gp/product/B019I9XYGA
I have no idea if it will work, but it's in stock via amazon uk -- so returns are easy. I don't need the wireless station (I may or may not keep), but the sensor can be ordered standalone, just not via amazon yet. I wanted an easy to return unit so I could figure out what might work.
I suspect the oregon/TFA/Bressel ones would work OOTB
Interesting to see the banggood ones work fine.
I'll report back, probably tomorrow.
Posted: Friday 19 February 2016 19:16
by kman
@planetf1 - thanks, will look forward to your report tomorrow.
Posted: Sunday 21 February 2016 18:34
by planetf1
@kman - sorry it's a no go. I'm going to see how people report the battery life of the banggood sensor which is know to work for £7 albeit delivery from china, else I may just get a TFA or oregon
The rfx picked up no new device either within domoticz or when moved across to windows/rfxmngr.. Tried all 3 channels, and forced transmit on the sensor (test button). I also had undecoded message reporting enabled on the rfxtrx433e ...
Posted: Monday 22 February 2016 12:22
by planetf1
I've decided to order the banggood one. It's perhaps a 1/3 of the cost of any known good working ones (oregon/tfa) from the docs/amazon so worth a shot, especially as I may need a couple more... so it's a case of waiting for delivery now!
Posted: Thursday 25 February 2016 9:42
by mverleun
Have you tried to integrate RTL_433 (
https://github.com/merbanan/rtl_433) ?
I'm using it to receive information from a weather station that is not supported by RFXTRX and submit it to Domoticz via MQTT.
This is a cheap solution if you only need to receive data.
Posted: Thursday 25 February 2016 10:35
by simonrg
5 minutes with
http://www.esp8266.nu/index.php/HumiditySensor
ESPeasy firmware is really easy - just burn the firmware - connect up my DHT22 temp / humdity sensor, create dummy temp /hum sensor in Domoticz, configure ESPeasy web interface on my Wemos D1 Mini and magically data starts being sent to Domoticz - a £8 temperature / humidity sensor. Using a cheaper version of the ESP8266 and DHT11, you could get the price below £5 and buying from China direct about £2.50. You would have to factor in some sort of case / power supply.
