New protocols. When available in Domotics? [SOLVED]
albinsson
Post by albinsson »
Last ext. firmware ver. 251 adds support for sending "HQ"/"Coco 20".
Great for me since I have 12 switches using that protocol . ( FHT-7901 from Kjell&Co.)
I have confirmed they work in RFXmanager but in the dropdown list when manually adding switches in Domoticz - "HQ/Coco-20" isn't available.
Is that a bug? Or is it normal, and I have to wait for next release of Domoticz to have it suppirted there?
Skickat från min SM-G900F via Tapatalk
Last edited by albinsson on Wednesday 10 February 2016 12:00, edited 1 time in total.
gizmocuz
Re: New protocols. When available in Domotics?
Post by gizmocuz »
Why do you think when something is not supported that this is a bug ?
And on which version are you running, did you try to install the latest beta version?
You would be surprised.....
gizmocuz
Post by gizmocuz »
And you searched the forum and found this
http://www.domoticz.com/forum/viewtopic.php?t=10428
albinsson
Post by albinsson »
Im sorry for not searching the forum correctly. My bad.
Did I say that i think it's a bug? Or did I ask politely IF it's a bug or IF it's normal, and update of Domoticz is necessary?
The reason for the question is that I thought all this was handled within the Firmware of the RFXtrx433e, same as supported protocols to enable/disable for recieving.
Im running the SD image since some weeks so that explains it.
No need to be harsh..
