Fibaro Universal Binary Sensor wrong temperature readings rate
Posted: Tuesday 09 February 2016 17:27
I have connected one universal binary sensor with two temperature sensor DS18B20. I use a Razberry module on a raspberry. I want to have both temperature reading every 5 seconds, so I set the configuration parameter 10 to 5s and the parameter 11 to 20s. What I get is a temperature reading every 10s for one sensore and one reading every 10minutes for the other one. Does any one has the same problem?
The fibaro sensor is powered at 24V with a laboratory power supply.
thanks a lot in advance for any help
