Advice needed on moving rfxtrx to other pi with ser2net
Posted: Tuesday 09 February 2016 1:01
by stlaha2007
Hi there,
Seen some posts on ser2net and i'm able to move the rfxtrx433 to another pi near some KaKu switches and Alecto Wind and Temp-Hum device.
I have prepared the new PI with ser2net, rfxtrx is inserted and is seeing the Alecto devices.
I also added a new device on the original PI as RFXcom LAN.
How do i move the current devices on the original PI so that temp/wind/rain and switches keep their history?
As easy as add new from rfx-lan and replace? And what about the KaKu-switches, not pleased if i have to "learn" them again
Any advice will be welcome.
Grtz,
Stephan
Re: Advice needed on moving rfxtrx to other pi with ser2net
Posted: Tuesday 09 February 2016 6:11
by bizziebis
You don't need to make a new device 'RFXcom LAN', just change the com port of the old RFXcom. All switches will work like they did before.
Posted: Tuesday 09 February 2016 8:41
by gizmocuz
You select the original serial rfxcom hardware, change it's type to rfxcom lan, correct the settings, and press update
(always make a backup before you do this)
Posted: Tuesday 09 February 2016 10:06
by stlaha2007
Thanks guys.
Backup runs... Havent tested yet...
Changing current hardware type from usb to LAN looks promising...
Gonna test it first on the other new PI...
Have a domoticz build from source there to test...
Again thanks for the advise.
Grtz,
Stephan
Posted: Wednesday 10 February 2016 7:49
by stlaha2007
Tested and works great...
I can imagen there are other with more PI's or arduino's with the same question howto setup and/or move hardware devices remote without a second domoticz setup.
So is this kind of setup/move handy for a new wiki page?
Grtz,
Stephan
Posted: Wednesday 10 February 2016 8:29
by gizmocuz
Its quite standard stuff
And when you make a backup and start playing, you can't damage anything
Posted: Wednesday 10 February 2016 9:06
by stlaha2007
Sure ! Backup saved my day several times... Like living on the edge.
Wiki-page suggestion (wanna wright it myself) perhaps handy for those searching the "standard" options.
Mostly 'just' changing the hardware-type was a big issue, haven't found it mentioned in manual/wiki/forum as a possibility. On the other end quite obvious.
Grtz,
Stephan
Posted: Wednesday 10 February 2016 9:23
by gizmocuz
Good it is here then
