RFXtrx firmware update 95/195/251
Posted: Monday 08 February 2016 11:06
by b_weijenberg
New firmware is available.
See blog.rfxcom.com
Lighting4 is improved and you can now enable ARC and Ligthing4 together.
Many cheap sensors equiped with the PT2262 or EV1527 are supported including Chuango.
Avantek (2300W/10A - with On/Off switch) is available at:
France http://www.amazon.fr/s/ref=sr_pg_3?rh=i ... 1454924251
Italy http://www.amazon.it/AVANTEK-Interrutto ... ds=avantek
US http://www.amazon.com/AVANTEK-Switches- ... ds=avantek
Re: RFXtrx firmware update 95/195/251
Posted: Wednesday 10 February 2016 13:24
by Kubra
Hoi Bert,
I notice in the new firmware that a "new PCR800" is added. I assume the protocol for this device (raingauge Oregon PCR800) is rewriten or adjusted in this new firmware release?
I couldn't find any new hardwaretype/release of the Oregon PCR800.
Can you be more specific of the changes for this device?
Posted: Wednesday 10 February 2016 13:31
by b_weijenberg
Code is added to support this new version.
Posted: Wednesday 10 February 2016 20:25
by RayAmsterdam
How do I add the Chuango motion sensors? Wich protocol?
Re: RE: Re: RFXtrx firmware update 95/195/251
Posted: Wednesday 10 February 2016 20:39
by deennoo
RayAmsterdam wrote:How do I add the Chuango motion sensors? Wich protocol?
+1 did you allow to send chuango and does it works ?
Posted: Friday 12 February 2016 19:20
by RayAmsterdam
I don't see any signal from Chuango sensors.
Posted: Friday 12 February 2016 20:30
by b_weijenberg
sorry, next firmware version.
Posted: Saturday 13 February 2016 17:33
by RayAmsterdam
Good news Bert! When do you expect to release it?
Posted: Sunday 21 February 2016 15:31
by olleman
Since this new firmware version I've re-added my PT2262 devices (just one at the moment) as Lighting 5 (BBSB). This one is a door sensor and I use it together with "On delay" to have the door be set "closed" automaticly after a few seconds. This operation is impossible to achive since the device is recognized as "lighting 5". It ignores the "on delay" command for the switch and it always stays closed. I have also tried to solve it with a simple event but it's the same...
Anyone know of a solution for this? I need this functionallity since the logic of my alarm depends on it.
,Olle
Posted: Tuesday 13 June 2017 8:58
by erwindw
olleman wrote:Since this new firmware version I've re-added my PT2262 devices (just one at the moment) as Lighting 5 (BBSB). This one is a door sensor and I use it together with "On delay" to have the door be set "closed" automaticly after a few seconds. This operation is impossible to achive since the device is recognized as "lighting 5". It ignores the "on delay" command for the switch and it always stays closed. I have also tried to solve it with a simple event but it's the same...
,Olle
Hi there,
Have you ever found a solution to this problem? I've updated the firmware of the RFXcom yesterday: all PT2262 sensors wich used to work perfect now aren't anymore. Domoticz now recognized them as Lightning 5 in stread of Lightning 4... thanks in advance!
