Interfacing to PIR sensor wiring in existing alarm panel
muddymickey
Post by muddymickey »
Hi all
I'd like to use Domoticz (with Raspberry Pi + Razberry) to control lights etc via Z-Wave.
It would be nice to use the existing PIR sensors of my alarm system as triggers to switch the lights.
Does anyone know of a way to interface to the PIR wiring in my alarm panel ?
Many thanks for any ideas...
cul8r
Re: Interfacing to PIR sensor wiring in existing alarm panel
Post by cul8r »
You need to have information on how your alarm is connected and function. One way is with Fibaro Universal Sensor, install it between your PIR and the alarm control unit:
http://www.fibaro.com/manuals/en/FGBS-3 ... -v1.01.pdf
/C
C4rtm4N
Post by C4rtm4N »
What type of alarm do you have MuddyMickey & does it do IP comms?
I have a Texecom & wrote a python script to check every couple of seconds. Works fine for reporting but the lag is too great to turn lights on when you enter a room.
blackdog65
Post by blackdog65 »
I built a little mysensors arduino mini pcb with 7 inputs and found it works fine. The fibaro binary works well but is expensive and only sees 2 sensors.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
