Hi all!
I'm back in buseniss; after a lot of support in the nodo-domotica forum, I managed to get everything up & running, using the NodoTool to send an eventlist to my slave. Unfortunately, it doesn't show up in Domoticz yet. The good new is, I see stuff happening when getting the debug output from the RFLink Loader. This is what I get:
'Default mode':
20;02;Slave;ID=000201;DEBUG=0016;
20;03;Slave;ID=000201;DEBUG=0016;
Debug mode:
20;05;DEBUG;Pulses=194;Pulses(uSec)=2970,900,420,390,1410,390,420,390,1410,390,390,390,390,390,390,390,390,390,390,390,1410,390,390,390,390,390,390,390,1410,390,390,390,390,390,390,390,390,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,1410,390,420,390,420,390,420,390,390,390,390,390,390,390,390,390,390,390,390,390,1410,390,390,390,390,390,390,390,390,390,390,390,1410,390,390,390,390,390,390,390,390,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,390,390,420,390,1410,390,390,390,1410,390,390,390,390,390,1410,390,1410,390,390,390,1410,390,1410,390,390,390,390,390,390,390,420,390,420,390,1410,390,420,390,1410,390,1410,390,420,390,420,390,420,390,420,390,420,390,420,6990;
20;06;Slave;ID=000201;DEBUG=0016;
I can't quite understand what this means
But someone overhere can perhaps? From above, I know the unit should be for example '2'. which I did with the SetUnit command. The variable I send through RF is 1, and contains the temperature.
This is the debug output from my Nodo Small:
8:09:37 !******************************************************************************!
8:09:37 Nodo Domotica controller (c) Copyright 2014 P.K.Tonkes.
8:09:37 Licensed under GNU General Public License.
8:09:37 Nodo-Small V3.7, Product=SWACNC-SMALL-R744, ThisUnit=2
8:09:37 Direction=Output, Source=All, Unit=2, Event=Boot 2
8:09:37 Direction=Input, Source=System, Unit=2, Event=Boot 2
8:09:37 Direction=Input, Source=EventList, Unit=2, Event=TimerSet 1,60
8:10:37 Direction=Input, Source=Clock, Unit=2, Event=Timer 1
8:10:37 Direction=Input, Source=EventList, Unit=2, Event=TimerSet 1,60
8:10:37 Direction=Input, Source=EventList, Unit=2, Event=WiredOut 2,On
8:10:37 Direction=Input, Source=EventList, Unit=2, Event=TempRead 1,1
8:10:38 Direction=Input, Source=Plugin, Unit=2, Event=VariableSet 1,22.06
8:10:38 Direction=Input, Source=System, Unit=2, Event=Variable 1,22.06
8:10:38 Direction=Input, Source=EventList, Unit=2, Event=VariableSend 1,RF
8:10:38 Direction=Output, Source=RF, Unit=2, Event=Variable 1,22.06
8:10:38 Direction=Input, Source=EventList, Unit=2, Event=WiredOut 2,Off
8:10:38 Direction=Input, Source=EventList, Unit=2, Event=Sleep 0,0
Help
What is wrong?
Regards,
Marco
