Error with LUA script
Roncalli
Post by Roncalli »
I am executing the following LUA script (created via the Domoticz HTML interface):
if (devicechanged['Arm 1 partition'] == 'On') then
    if (otherdevices_svalues['Output:Anzeige S-intern'] == 'Off') then
        commandArray['Scene:AllesAus']='On'
        commandArray['Arbeitszimmer']='On'
        commandArray['Badezimmer']='On'
and get the following error message:
"Error: EventSystem: in ExternScharf_AllesAus: [string "-- ..."]:28: attempt to index global 'devicechanged' (a nil value)"
Can anyone tell me what I am doing wrong?
Thanks! F.
Domoticz Stable on RaspberryPi 3B+ running stretch-light
Aeon-Labs stick with 23 z-wave devices, RFXtrx with 14 devices, Netatmo with 6 modules, Satel Integra, Instar IP Camera
jvdz
Domoticz version: 4.107
Re: Error with LUA script
Post by jvdz »
Did you mark this script as Time Event as in that case the whole devicechanged array won't be available?
Jos
gertlind1
Post by gertlind1 »
Also, look at below.
viewtopic.php?f=23&t=9992
Gert
Roncalli
Post by Roncalli »
Hi Jos,
Thanks for helping out again. I changed the script to device event. Now it works flawlessly.
F.
Alle
Post by Alle »
jvdz wrote:Did you mark this script as Time Event as in that case the whole devicechanged array won't be available?
Jos
Maybe a stupid question, but how can you mark a script as Time Event? I have also have "'devicechanged' (a nil value)" in the log.
ESXi/Ubuntu - Z-wave.me USB Stick - Domoticz Beta - EvoHome - Nest Protect - Logitech Media Server - Netatmo Weather Station - Everspring - Aeonlabs
niceandeasy
Domoticz version: 3.8153
Post by niceandeasy »
The question is not stupid, it's just not necessary to ask. The answer is in the Domoticz wiki.
https://www.domoticz.com/wiki/Events chapter 2.
