Zwave problems with domoticz
Posted: Tuesday 02 February 2016 21:03
Hi i have a raspberry Pi 1b with the latest domoticz beta software
I use openzwave with
(hardware in open zwave)
012 (0x0c) Unknown Aeotec Smart Switch 6 2016-02-02 20:52:34 Nee [Herstel Node]
011 (0x0b) Unknown Aeotec Smart Switch 6 2016-02-02 20:52:34 Nee [Herstel Node]
004 (0x04) Unknown Everspring AN158 Plug-in Meter Appliance Module 2016-02-02 20:52:36 Ja [Herstel Node]
001 (0x01) Controller Aeon Labs Z-Stick S2 2016-02-02 20:52:34 Nee [Herstel Node]
Everything worked fine in the open zwave control panel and also in domoticz till i add two new devices: 2 Aeotec Smart swict 6 zwave+ The rest of the hardware is not zwave+
In the zwave open control panel i can swith on/off every device.
When using domoticz it sometimes works and after a while the devices become dead....
When i only use the open zwave control panel it looks if there are no problems...
hardware in control panel openzwave
1 *LB Static Controller Static PC Controller Aeon Labs Z-Stick S2 Controller 20:52:35 Ready
4 LBR Routing Slave Binary Power Switch Everspring AN158 Plug-in Meter Appliance Module Unknown on 20:57:28 Ready
11 LBR Routing Slave Routing Slave Aeotec Smart Switch 6 Unknown on 20:57:17 Ready
12 LBR Routing Slave Binary Power Switch Aeotec Smart Switch 6 on 20:58:22 Ready
i deleted and installed it many times factoryreset everything... some an idea or is the combination raspberry 1b domoticz zwave and zwave + devices not compatible?
With only one zwave device it worked perfect!
