Temperature read out Pi without Domoticz
Posted: Sunday 31 January 2016 17:25
by Cubic
I want to read out the system temperature of my second Pi without install Domoticz on it.
Can anyone tell me if this is possible ?
And if the answer is yes, how ;)
Re: Temperature read out Pi without Domoticz
Posted: Sunday 31 January 2016 17:41
by paulvha
try : /opt/vc/bin/vcgencmd measure_temp
Posted: Sunday 31 January 2016 18:37
by Cubic
Thanks Paul
What I want is read the temperature from the second Pi in Domoticz installed on the first Pi.
But without install Domoticz on the second Pi
Posted: Sunday 31 January 2016 19:25
by Mozart
I have this implemented. Here is what I did (feel free to optimize this :D ):
1. Install python on the second pi.
2. create a file e.g. temp.py with the following content:
#!/usr/bin/env python
import tornado.ioloop
import tornado.web
import os
class MainHandler(tornado.web.RequestHandler):
    def getCPUtemperature( self ):
        res = os.popen('vcgencmd measure_temp').readline()
        return(res.replace("temp=","").replace("'C\n",""))
    def get(self):
        self.write( "%s" % ( self.getCPUtemperature() ) )
application = tornado.web.Application([
    (r"/", MainHandler),
if __name__ == "__main__":
    application.listen(8888)
    tornado.ioloop.IOLoop.instance().start()
The last line of the code shows the port number that is used. Start this code with:
python temp.py
Now use a browser to connect to the ip or name of your second pi on port 8.8.8.8, e.g.:
http://192.168.254.9:8888/
You should get a page with only the temperature, if this is showing the temp you have to solve this first.
To autostart this script at every boot you should create a script in /etc/init.d/ to make that work. There are examples on the internet how to do that, if you cannot get it working I will paste my /etc/init.d/ script for this.
Next, add a dummy temperature device in Domoticz. Go to the list of devices and make an note of the device number, we will need this later.
Past the following code to a script in e.g. /home/pi/domoticz/scripts (PI with Domoticz) and name it something like get-pi-temp.sh:
#!/bin/bash
#replace with your Device IDX you found in the previous step.
SecondPi=44
#Internal temperature SecondPI
TEMP=$(curl http://<name or IP of your second PI:8888)
curl --connect-timeout 60 "http://localhost:8080/json.htm?type=command&param=udevice&idx=$PiZolder&nvalue=0&svalue=$TEMP"
Make sure that you get the details right.
Make the script executable with:
chmod +x /home/pi/domoticz/scripts/get-pi-temp.sh
I use Cron to run this script every 5 minutes. Update your local cron on the first PI with these commands:
type: crontab -e (as user pi)
add this to the end of the file:
*/5 * * * * /home/pi/domoticz/scripts/get-pi-temp.sh >/dev/null 2>&1
Now you should get a new temperature reading every 5 minutes in your Domoticz. Works for me, I have do this to retrieve the temp of 2 PI's that do not have Domoticz. On 1 PI I also connected 3 ds18b20 probes connected to the GPIO of that PI and pass them in a similar way to Domoticz.
Good luck!
Posted: Sunday 31 January 2016 21:10
by Cubic
Thank you for the script and the explanation
Posted: Monday 05 September 2016 21:55
by erigoth
Hello Mozart,
you wrote:
Mozart wrote: To autostart this script at every boot you should create a script in /etc/init.d/ to make that work. There are examples on the internet how to do that, if you cannot get it working I will paste my /etc/init.d/ script for this.
I've tried to get it to work in many ways:
1. @reboot in crontab
2. added bashscript to /etc/init.d
3. created a service for the bash script
the script starts, it just shows a blank page on the 8888 port...
when I kill the script and start it manually it works perfect but it wont start normally on reboot.
could you please share your script with me?
Hope you can help me.
greets,
Erigoth
Posted: Sunday 13 November 2016 19:36
by Mozart
erigoth wrote:Hello Mozart,
greets,
Erigoth
Oops, missed this. Do you still need the script?
Posted: Monday 14 November 2016 0:12
by stlaha2007
As the first reply already mentioned use the raspbian supplied tools.... In the following script it reads the temperature of the pi and pushes it into domoticz and only requires the idx for the tempsensor within domoticz.
Run it with cron every 5 minutes like:
*/5 * * * * /home/pi/scripts/get_temp.sh 221
Script placed in /home/pi/scripts/get_temp.sh:
#!/bin/bash
Current_Temp=$(/opt/vc/bin/vcgencmd measure_temp | cut -c6-9)
IDX=$1
echo $Current_Temp
curl -s "http://domoticz.ip.address:8080/json.htm?type=command&param=udevice&idx=$(echo $IDX)&nvalue=0&svalue=$(echo $Current_Temp)"
Also don't forget to: chmod +x /home/pi/scripts/get_temp.sh
So the script can be executed.
Sent from my K00C using Tapatalk
