Uninstall on Windows 10 - and clean install
Posted: Sunday 31 January 2016 13:56
by Lemme
I am currently testing Domoticz with MySensor nodes. At a point I had to delete Domoticz and install it again.
However, all my nodes were showing up again after the re-installation. I simply cannot get a clean install of Domoticz now.
I use Windows 10 and have normal user rights, not admin. Can someone tell med how to do a clean install of Domoticz, or where to find the hidden files, so I can delete them myself.
Br
Flemming
Re: Uninstall on Windows 10 - and clean install
Posted: Sunday 31 January 2016 14:15
by js26936
.. did you exclude your nodes from your network before ??? If not, they stord in your controller .
To get it clean you have to hardreset your controller, and manualy delete your install folder. Also look under programdata folder
Posted: Sunday 31 January 2016 14:41
by Lemme
No information about nodes are stored in the MySensor gateway. All information about nodes are stored at the Controller (Domoticz). Therefore, a clean install of Domoticz should not result in showing old nodes.
Br
Flemming
Posted: Saturday 26 November 2016 15:26
by foad62
I have the same problem. after uninstalling domoticz and deleting the domoticz folder. I installed Domoticz again but my gateway data appeared on hardware section. It seems the data are stored somewhere which uninstalling doesn't clear it!
Posted: Tuesday 06 December 2016 22:01
by MichealLocus
has this issue solved for you guys
Posted: Tuesday 24 January 2017 23:05
by chrisfraser05
not that its a problem personally but I've had domoticz on my system 3 times and each time I think i've completely removed it.... reinstall and its all still the same setup
Posted: Tuesday 21 February 2017 17:13
by ibniba
Guys,
I would be grateful if you might explain how to uninstall Domoticz in baby terms for a newbie.
I installed the stable version and now I need to install the beta - so I want to uninstall the stable on.
Posted: Monday 28 October 2019 23:10
by MichelvB
I had the same problem. I searched for Domoticz and found the directory with the database.
C:\ProgramData\Domoticz
Delete the database in that directory.
