Cleanup Database Topic is solved
Jtoler5
Cleanup Database
Post by Jtoler5 »
I added a Monoprice Dual Zwave relay, that has since been removed, but ever since I did that I now see a lot of devices that do not exisit and sending a command to them results in a unable to contact error. Is there anyway to clean up devices in Domoticz database?
Screen Shot 2016-01-29 at 1.02.04 PM.jpg (187.26 KiB) Viewed 2674 times
gizmocuz
Re: Cleanup Database
Post by gizmocuz »
Yes, from the same view, select them and press delete ?
Jtoler5
Post by Jtoler5 »
gizmocuz wrote:Yes, from the same view, select them and press delete ?
I only get that option if I'm under Hardware and OpenZwave setup. This is under the Devices page.
Jtoler5
Post by Jtoler5 »
Didn't notice the small trash icon. Never mind. Thanks
