airquality
htca
airquality
Post by htca »
hi, I have my domoticz server up and running on a raspberry pi for a few days. Uptil now, I run a system which monitored several things, like gas, electricity and water use (selfmade monitoring system using a ADC and 3 sensors). I was able to add those to domoticz using dummy hardware and a counter. On my old server I also collect information about the airquality from internet (there is a station close to my home, which publishes on the internet). I would like to push them as well to domoticz, however my airquality is defined as mug/m^3 for 8 different polluting porticles. In the dummy hardware there is an airquality but thats for CO2 and defines only in ppm. I could use that, but it is a bit dirty to do (and not fully correct). I added 8 user variables, but it seems that I cannot log them as a device (is that correct). Can anybody give me hint howto do this?
epierre
Re: airquality
Post by epierre »
same issue here, to I converted to ppm/ppg and sent it to this ill named CO2.
what are you using to mesure gases ? My page here: http://forum.mysensors.org/topic/147/air-quality-sensor
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
gizmocuz
Re: airquality
Post by gizmocuz »
Air quality is in PPM
epierre
Re: airquality
Post by epierre »
right now yes, and still shows "CO2" in the axis sadly.
There are some formulae out there to go to ppm but some gases are in ppb (like the dangerous CO).
gizmocuz
Re: airquality
Post by gizmocuz »
And is that air quality ?
epierre
Re: airquality
Post by epierre »
Air quality https://en.wikipedia.org/wiki/Air_quality_index by definition is a combination of all this (see how to compute):
O3 (ppb) O3 (ppb) PM2.5 (µg/m3) PM10 (µg/m3) CO (ppm) SO2 (ppb) NO2 (ppb)
so sorry not only ppm ;-)
htca
Re: airquality
Post by htca »
Actually, I get all my parameters in μg/m3, last readings:
NO2 50
NO 9
O3 27
PM10 16
PM25 7
C6H6 1
C7H8 0
SO2 3
So if there is a unit conversion to ppb.... Please point me to it (but it has a relation with temperature and airpressure I guess).
htca
Re: airquality
Post by htca »
epierre wrote:Hello,
I get my data from a public source on the internet.
epierre
Re: airquality
Post by epierre »
huh I am interrested by that source for I haven't found a decent SO2 sensor yet, only fakes...
epierre
Re: airquality
Post by epierre »
htca wrote:Actually, I get all my parameters in μg/m3, last readings:
NO2 50
NO 9
O3 27
PM10 16
PM25 7
C6H6 1
C7H8 0
SO2 3
http://www.lenntech.com/calculators/ppm ... illion.htm
some common gases are listed, else you would need their molecular weight
htca
Re: airquality
Post by htca »
It is in the Netherlands:
www.luchtmeetnet.nl
htca
Re: airquality
Post by htca »
Anyway, I would appreciate if I could use some dummy parameter, so which one should I use?
epierre
Re: airquality
Post by epierre »
you have the most common CO CO2 O3 SO2... should be a good start
epierre
Re: airquality
Post by epierre »
the above gives these values:
NH3 17.03 g/mol
CO2 44.01
CO 28.01
H2S 34.08
NO2 46.01
NO 30.01
O3 48.00
C6H6 78.11
C7H8 92.14
you have:
NO2 50 μg/m3 gives 26,5868821 ppm
O3 27 μg/m3 = 0.027 mg/m3 -> (8,31441*298,15)/(48*101,325)*27=13,7617025 ppm
correct me if I'm wrong
