How to configure cheap sensors with PT2262
Posted: Wednesday 27 January 2016 13:16
by b_weijenberg
The RFXtrx433 and RFXtrx433E transceivers are able to receive the PT2262.
The 3M3 oscillator resistor must be selected.
The PT2262 packets can be received in Lighting4 as a bit pattern but can also be received as an ARC On or Off packet if the PT2262 pins are configured as follows:
L=Low,
F=Floating (not connected),
H=High (not used)
PT2262       A0  A1  A2  A3   housecode
             L   L   L   L    A
             F   L   L   L    B
             L   F   L   L    C
             F   F   L   L    D
             L   L   F   L    E
             F   L   F   L    F
             L   F   F   L    G
             F   F   F   L    H
             L   L   L   F    I
             F   L   L   F    J
             L   F   L   F    K
             F   F   L   F    L
             L   L   F   F    M
             F   L   F   F    N
             L   F   F   F    O
             F   F   F   F    P
PT2262       A4  A5  A6  A7   unitcode
             L   L   L   L    1
             F   L   L   L    2
             L   F   L   L    3
             F   F   L   L    4
             L   L   F   L    5
             F   L   F   L    6
             L   F   F   L    7
             F   F   F   L    8
             L   L   L   F    9
             F   L   L   F    10
             L   F   L   F    11
             F   F   L   F    12
             L   L   F   F    13
             F   L   F   F    14
             L   F   F   F    15
             F   F   F   F    16
PT2262       D3  D2  D1  D0
             L   F   F   F    ON
             L   F   F   L    OFF
Re: How to configure cheap sensors with PT2262
Posted: Saturday 07 May 2016 13:47
by finalcut62
Bert, is there a way to influence 'update frequency' with the PT2262? That is: I want to hook this up to a wireless moisture sensor, but I hate changing batteries and readings are needed < 2 times a day...
Thx again for Rfxcom: love the product. And on a side note: I get a LOT of readings from someone in my neighborhood. And the moment I see a PT2262 device that isn;t mine, I know he will likely have an Rfxcom too. That means I'm less and less inclined to use 433Mhz for control devices, but still a great fan of using it for sensor applications. I don't mind other folks reading my sensors, but I hate for others to control my lighting, shutters etc.!
Posted: Saturday 07 May 2016 16:47
by b_weijenberg
If the PIR or contact is triggered the PT2262 will transmit a few packets.
If the PT2262 is not triggered it will not send an RF packet.
Posted: Tuesday 31 May 2016 16:54
by b_weijenberg
The RFXtrx433(E) accepts a wider range of PT2262 and EV1527 pulse timing starting at firmware version 1001 released Feb 18,2016.
Posted: Monday 15 August 2016 23:24
by Goldwing1973
Bert,
I just updated my Domoticz and to my big suprise i have a new device, unknown to me
RFXcom433E 904014 0 Unknown Lighting 4 PT2262 On - 2016-08-15 23:15:08
As you might remember, i'm the one with the SEAV sunscreens, so i was hoping it might be one of them, but when i looked further i found a Byron SX Chime (the sunscreen) and the timestamp it's completely wrong between them
RFXcom433E 0055 6 Unknown Chime ByronSX On 7 2016-08-15 18:43:35
Is there any (easy way) to figure out who's and what device it is?
(i already stood in the garden clicking on the on/off button and listening in the hope i would hear someone curse his pants off, but no luck) *grin*
Posted: Tuesday 16 August 2016 9:20
by b_weijenberg
With Lighting4 and "Accept new Hardware Devices" enabled you have a high risk to receive many unknown devices because the PT2262 and compatibles don't have a check on valid packets.
For normal use it is advised to disable "Accept new Hardware Devices"
Posted: Tuesday 16 August 2016 14:46
by Goldwing1973
b_weijenberg wrote:With Lighting4 and "Accept new Hardware Devices" enabled you have a high risk to receive many unknown devices because the PT2262 and compatibles don't have a check on valid packets.
Ok, turning it off.
