Elro FA500S switches
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
I bought two switches including remote for € 9,99 (link)
Domoticz does recognise the commands from the remote but sees them as 3 different codes. I've enclosed some information from 3 on buttons that I pressed on the remote.
I've tried to learn the switch a manual code from Domoticz, but that didn't work. When I learn a command from the remote to Domoticz only one of the 3 commands get saved so the switch won't work.
The switches only have a learning mode, no dip switches or code wheels.
Button A - ON:
RfxCom 		0000080 2 	Unknown Lighting 	2 	HomeEasy EU 	On, 	Level: 100 % 	5 -   2013-11-30 13:35:15
RfxCom 		N 		9 	Unknown Lighting 	1 	ARC				On 						7 -   2013-11-30 13:35:15
RfxCom 		003F4B0 2 	Unknown Lighting 	2 	AC 				On, 	Level: 100 % 	7 -   2013-11-30 13:35:15
Button B - ON:
RfxCom 		0000080 3 	Unknown Lighting 	2 	HomeEasy EU	On, 	Level: 100 % 	5 -   2013-11-30 13:37:02
RfxCom 		N 		5 	Unknown Lighting 	1 	ARC				On 						7 -   2013-11-30 13:37:02
RfxCom 		003F4B0 3 	Unknown Lighting 	2 	AC				On, 	Level: 100 % 	6 -   2013-11-30 13:37:02
Button C - ON:
RfxCom 		0000080 4 	Unknown Lighting 	2 	HomeEasy EU	On, 	Level: 100 % 	5 -   2013-11-30 13:39:35
RfxCom 		N 		13	Unknown Lighting 	1 	ARC				On 						7 -   2013-11-30 13:39:35
RfxCom 		003F4B0 4 	Unknown Lighting 	2 	AC				On, 	Level: 100 % 	7 -   2013-11-30 13:39:35
Rfxcom manager
0B1100130003F4B002010F70
Packettype    = Lighting2
subtype       = AC
Sequence nbr  = 19
ID            = 003F4B0
Unit          = 2
Command       = On
Signal level  = 7
0B1101140000008002010F50
subtype       = HomeEasy EU
Sequence nbr  = 20
ID            = 0000080
Unit          = 2
Command       = On
Signal level  = 5
071001154E090170
Packettype    = Lighting1
subtype       = ARC
Sequence nbr  = 21
housecode     = N
unitcode      = 9
Command       = On
Signal level  = 7
b_weijenberg
Re: Elro FA500S switches
Post by b_weijenberg »
RFX-433, RFX-433EMC, RFX-868
bendora
Post by bendora »
Did you get it working?
I ve the same FA500s and i did not get it working.
It send two codes AC en HE EU.
I ve tried to link the codes manualy with no suc6.
bizziebis
Post by bizziebis »
No sorry, I gave them away.
Stuntteam
Post by Stuntteam »
This set is fully supported by the RFLink Gateway..
vinculuum
Domoticz version: V3.4834
Post by vinculuum »
Hi there, i also have some FA500S switches which i am not able to switch using my rfxcom with the latest firmware 1001 hw 1.3 EXT and domotics V3.4834 running on my synology. I tried several protocols HE EU, AC, IT and ARC but still nothing. Anyone some suggestions i could try? there driving me crazy
TnX
b_weijenberg
Use Ext2 firmware.
Configure an IT On/Off module in Domoticz for the FA500S.
Configure an IT Dimmer for the FA500DSS dimmer module.
Select a random ID and unit and add this as a new remote in the FA500.
Note: The FA500 can have up to 5 remotes paired. To remove all remotes from the FA500 set the module in pairing mode and transit an All Off command.
vinculuum
Post by vinculuum »
It worked! it was the Ext2 firmware
cheers!
