Cheap wireless temp/humidity sensors in Scandinavia
DarkFoxDK
Post by DarkFoxDK »
Biltema sells a couple of different weather stations with wireless 433 MHz temperature & humidity sensors.
You can buy extra sensors individually for 89.90 DKK, and they work flawlessly with RFLink and Domoticz.
Personally, I've tested the 84-0871 model, and it got picked up immediately by the RFLink as a "Prologue", subtype "WTGR800".
There's a switch behind the battery door, allowing you to switch between 3 different "channels", so I assume that's the most you can have in the same area.
Larsja
Domoticz version: V2.3530
Re: Cheap wireless temp/humidity sensors in Scandinavia
Post by Larsja »
Thanks for the tip, ill check it out, im trying now with a sensor from Clas Ohlson, but it aint coming up in device list.
http://www.clasohlson.com/no/Temperatur ... er/36-1797
oopee
Domoticz version: 3.x
Post by oopee »
Good to know, thanks! I've tested 84-056 with no luck (rfxcom/rflink).
jumbotroll
Post by jumbotroll »
Larsja wrote:Thanks for the tip, ill check it out, im trying now with a sensor from Clas Ohlson, but it aint coming up in device list.
This sensor is not working here with RFXCOM, but it's working with RFLink.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Larsja
Post by Larsja »
oopee wrote:Good to know, thanks! I've tested 84-056 with no luck (rfxcom/rflink).
This is now working with RFLink, think its in update 1.39
thestewed
Domoticz version: 3.4866
Post by thestewed »
I use a couple of these with my RFXtrx433E. You need to enable the Hideki/UPM protocol which is only supported by the Type 1 firmware. Their range is pretty bad though.
pj-r
Domoticz version: V3.8650
Post by pj-r »
Can confirm this. I have three of these in use.
DarkFoxDK
Post by DarkFoxDK »
I've got three of them. Two were working, but one device wasn't. The latest RFLink update has fixed it.
mpx2
Domoticz version: 4.10717
Biltema 84-0871 humidity/temperature sensor
Post by mpx2 »
How many of these Biltema 84-0871 sensors you can use simultaneously with Domoticz?
I know that these sensors support 3 channels but what does that mean? In this picture I can see different ID for every sensor. So can you add eg 5 of these sensors to your Domiticz?
mpx2
Post by mpx2 »
I found similar sensor
Renkforce Ersatz-/Zusatzsensor KL4931 Thermo-hgyro sensor 433 MHz wireless
https://www.conrad.com/ce/en/product/13 ... z-wireless
Price is 28,99 €.
Same sensors Art. 84-0871 in Biltema costs 10,90 €.
Clas Ohlson is selling teperature/humidity sensor Co/Tech 36-6726. 9,90 €
