Problem Update Elec Smart P1
Posted: Monday 25 January 2016 7:38
by nepheris
Hello I have some problem with updating a virtual Smart P1 on Domoticz.
Domoticz is running on as Raspi and i importing data form a Homewizard box via the API of the box. I made a script (see below) that send the following Html request to update Domoticz Smart P1 (Idx 65) via an Html wget. When I launch the script mannually "sudo bash /home/pi/hw/script/hw2domoticz-CompteurElecV2.sh " even 10 times per minute this script is works perfectly
but as soon I am lauching it via the same command in crontab every 15min this virtual sensor get corrupted.
I am updating some temperature , Electric, kWh, and many other domoticz virtual sensor by the same method (script that is periodically lauched by crontab) without problem.
You will find below the Domoticz IDX request to see what the sensor corruption look like & my bash script that should be lauched via crontab every 15min
Can you please help me ?
http://IPDomoticz:PORT/json.htm?type=devices&rid=65
ActTime: 1453701214,
ServerTime: "2016-01-25 06:53:34",
Sunrise: "08:30",
Sunset: "17:33",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
Counter: "0.000",
CounterDeliv: "0.000",
CounterDelivToday: "0.000 kWh",
CounterToday: "0.000 kWh",
CustomImage: 0,
Data: 1004;0;0;0;240;0",, ==> this one change to "0, ;0;0;0;170;0",
Description: "",
Favorite: 0,
HardwareID: 5,
HardwareName: "Dummy",
HardwareType: "Dummy (Does nothing, use for virtual switches only)",
HardwareTypeVal: 15,
HaveTimeout: false,
LastUpdate: "2016-01-25 06:53:04",
Name: "Idx 65 Elec P1 Smart Meter",
Notifications: "false",
PlanID: "0",
PlanIDs: [
0
],[/sub]
##!/usr/bin/bash
## sudo bash /home/pi/hw/script/hw2domoticz-CompteurElecV2.sh
ConsokWh=`cat HWsensors| jq ".response.energymeters[0].dayTotal"|tr -d '\n'` # echo $ConsokWh
EDFcompteurhier2359=$(cat EDFcompteur) #echo $EDFcompteurhier2359
EDFcompteurTemp=$(bc <<< "$ConsokWh+$EDFcompteurhier2359") #echo $EDFcompteurTemp
EDFcompteurTempENTIER=$(bc <<< "($EDFcompteurTemp+0.5)/1") #echo $EDFcompteurTempENTIER
IDX="65" IPdomoticz="http://192.XXX.XXX.XX:PORT"
USAGE1=$EDFcompteurTempENTIER
USAGE2="0"
CONS=$InstantWatt
RETURN1="0"
RETURN2="0"
PROD="0"  # si production courant
DomoticzElecP1url=$IPdomoticz"/json.htm?type=command&param=udevice&idx="$IDX"&nvalue=0&svalue="$USAGE1";"$USAGE2";"$RETURN1";"$RETURN2";"$CONS";"$PROD
wget -i $DomoticzElecP1url -O /dev/null   # echo $DomoticzElecP1url~
Re: Problem Update Elec Smart P1
Posted: Saturday 30 January 2016 15:08
by paulvha
I had a look, but this is straight forward. Are you sure that the value EDFcompteurTempENTIER / USAGE1 is correct all the time before updating ? Maybe an echo to append to a tmp_file of DomoticzElecP1url just before wget from debug ? At least we then know what direction to look.
Posted: Thursday 31 October 2019 12:46
by erem
not sure if this will help, but the shebang format is #!/usr/bin/bash, not ##!/usr/bin/bash
