Unable to include a Z-wave switch
Posted: Sunday 24 January 2016 22:00
Hello
Synology DS212 Version: 2.4298 Openzwave 1.4.3 latest version
I've just bought a switch AEON Labs micro smart G2 with meter DSC18 for Europe.
http://www.domadoo.fr/fr/peripheriques/ ... 11014.html
Which is supported by DZ http://www.domoticz.com/wiki/Hardware#A_2
and by OZW https://github.com/OpenZWave/open-zwave ... fig/aeotec
file msesV2.xml
After inclusion, and Synology restart, the node is recognized and then declared as dead
and then
and of course the node is flagged with a red mark in the status column (node tab of the Setup/Hardware screen.
nodeID = 14, description is empty
Do you have any suggestion ? How to include this device ?
Thanks for your help
file msesV2.xml
2016-01-24 11:22:26.605 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-01-24 11:22:26.607 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-01-24 11:22:26.608 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-01-24 11:22:26.609 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2016-01-24 11:22:26.610 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 3
2016-01-24 11:22:26.610 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 4
2016-01-24 11:22:26.611 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 5
2016-01-24 11:22:26.612 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 6
2016-01-24 11:22:26.612 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Energy, Instance: 1
2016-01-24 11:22:26.653 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Energy, Instance: 2
2016-01-24 11:22:26.653 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Energy, Instance: 3
2016-01-24 11:22:26.656 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Energy, Instance: 4
2016-01-24 11:22:26.656 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Energy, Instance: 5
2016-01-24 11:22:26.656 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Energy, Instance: 6
2016-01-24 11:22:26.657 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Power, Instance: 1
2016-01-24 11:22:26.658 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Power, Instance: 2
2016-01-24 11:22:26.659 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Power, Instance: 3
2016-01-24 11:22:26.660 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Power, Instance: 4
2016-01-24 11:22:26.661 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Power, Instance: 5
2016-01-24 11:22:26.661 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Power, Instance: 6
2016-01-24 11:22:26.695 RFXCOM: Using serial port: /dev/ttyUSB0
[color=#FF0000]2016-01-24 11:22:26.704 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1 [/color]
^[[31m2016-01-24 11:22:27.784 Error, Node014, ERROR: node presumed dead
^[[39m^[[32m2016-01-24 11:22:27.784 Always,
^[[39m^[[32m2016-01-24 11:22:27.784 Always, Dumping queued log messages
^[[39m^[[39m^[[39m^[[39m^[[39m^[[39m^[[39m^[[39m^[[39m^[[32m2016-01-24 11:22:27.784 Always,
^[[39m^[[32m2016-01-24 11:22:27.784 Always, End of queued log message dump
^[[39m2016-01-24 11:22:27.785 OpenZWave: Received Node Dead notification from HomeID: 25483669, NodeID: 14 (0x0e)
