TH14 - Alecto WS3500,WS4500
Jakke2440
Post by Jakke2440 »
I have found a temp/humidity sensor in my home by setting up your wonderful system with a RFXCOM
I see the signal on RFXman like:
Packettype    = TEMP_HUM
subtype       = TH14 - Alecto WS3500,WS4500
Sequence nbr  = 0
ID            = 14081
Temperature   = 17,8 °C
Humidity      = 142
Status        = Wet
Signal level  = 7  -64dBi
Battery       = OK
But I don't see him in domoticz... Am I doing something wrong?
geek
Domoticz version: 3.8833
Re: TH14 - Alecto WS3500,WS4500
Post by geek »
Hi, I have exactly the same problem. Like Domotics is just ignoring the sensor.
So I used RFXmngr to test, and the sensor is working when Rubicson is enabled.
I am using RFXCOM RFX433E
Firmware version = 1022
Firmware Type = Ext2
Sequence nbr  = 16
ID            = A001 decimal:40961
Temperature   = 27,1 °C
Humidity      = 129
Status        = Wet
Signal level  = 7  -64dBm
Battery       = OK
Did you solve this?? Has it still to be added to a new domoticz release? I would imagine that it should be possible to add this yourself by adding some stuff to an xml file. But I cannot find anything on that topic.
