Two Dooya Curtains in domoticz, diffrent behaviours?
Posted: Friday 22 January 2016 12:20
I have just installed my dooya curtain with the instructions in this thread:
viewtopic.php?f=4&t=2247&start=20
I couldn't see the curtain in domoticz or RFXmngr when I tried to pair it.. but when I manually added it according to the below values in the above thread everything works:
Blinds command
Packettype = BLINDS1
subtype = DC106
Sequence nbr = 31
id1-4 = 05040B6
Unit = 0
Command = Confirm/Pair
Signal level = 0
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 31
response = ACK, data correct transmitted
I'm however interested in buying another dooya curtain, but want to control them differently with two different scripts, that's If I for example have a block script in domoticz I might wan't to shut one of the curtains every day at one o clock, and the other curtain at three o clock, is this possible or will they react to the same command..?
Blinds command
subtype = DC106
Sequence nbr = 31
id1-4 = 05040B6
Unit = 0
Signal level = 0
Sequence nbr = 31
