play soundmessage with BT
Posted: Friday 22 January 2016 0:42
by johnnie
Hi guys, hopefully somebody can point me in the right direction.
I've installed an BT dongle with the help off: https://www.domoticz.com/wiki/BTAudio, and this working perfect, thnks!
When I launch the command from cli, it's working like a charm:
mplayer -ao alsa:device=bluetooth /media/alarm_ingeschakeld.mp3 -softvol -volume 30 -af resample=16000:0:0
Then I've integrated it in a bash script named: alarmaanmp3. This script contains:
#!/bin/sh
When I run this from cli, it's also working:
/home/pi/domoticz/scripts/alarmaanmp3
Now comes the part I got stuck, I've made a dummy swith and put the command in the "on" part of it (did the same for "off", but this has the same results):
In the log I see the script got activated, but no sound.
After this I've changed to LUA and made the script, named: script_device_alarmmessages.lua.
This script contains the following code:
  if (otherdevices['AlarmActive'] == 'On') then
    os.execute('/home/pi/domoticz/scripts/alarmaanmp3')
    print('Alarm message -aan- verstuurd naar BT-speaker')
I can see the print output in the log, but also here no sound.........
Hopefully somebody can help me with this puzzle.....
btw: I'm running Version: 2.3530, Build Hash: 9eef872, Compile Date: 2015-11-01 11:41:18
Re: play soundmessage with BT
Posted: Friday 22 January 2016 4:41
by nayr
try giving it the full path to mplayer, run 'whereis mplayer' to find its location.
I take it your scrpt is executable? chmod +x /home/pi/domoticz/scripts/alarmaanmp3
you might try using #!/bin/bash instead of sh, I am finding alot of little arm boxes that come with a default shell that sucks at scripting.
Posted: Friday 22 January 2016 10:15
by johnnie
Hi nayr,
Thnks for you're prompt response, script was indeed executable but checked it just to make sure.
Found mplayer and placed full path in the script, also changed it to bash, now I've got:
#!/bin/bash
/usr/bin/mplayer -ao alsa:device=bluetooth /media/alarm_ingeschakeld.mp3 -softvol -volume 30 -af resample=16000:0:0
Still no luck.
A friend of mine maringo, also on this forum, thinks it got something to do with "rights". As mentioned earlier I've completed the setup from wiki under the user "pi". Is this oke, or had I done it under "root"?
maringo also suggested to run: "sudo mplayer" instead of "/usr/bin/mplayer".
But when i do this i get the folowing output:
MPlayer svn r34540 (Raspbian), built with gcc-4.6 (C) 2000-2012 MPlayer Team
Playing /media/alarm_uitgeschakeld.mp3.
libavformat version 53.21.1 (external)
Mismatching header version 53.19.0
Audio only file format detected.
Load subtitles in /media/
Requested audio codec family [mpg123] (afm=mpg123) not available.
Enable it at compilation.
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
libavcodec version 53.35.0 (external)
Mismatching header version 53.32.2
AUDIO: 16000 Hz, 1 ch, floatle, 129.4 kbit/25.27% (ratio: 16175->64000)
Selected audio codec: [ffmp3float] afm: ffmpeg (FFmpeg MPEG layer-3 audio)
[AO_ALSA] alsa-lib: pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM bluetooth
[AO_ALSA] Playback open error: No such file or directory
Failed to initialize audio driver 'alsa:device=bluetooth'
Could not open/initialize audio device -> no sound.
Audio: no sound
Video: no video
Exiting... (End of file)
Posted: Friday 22 January 2016 14:02
by johnnie
Find the solution with the help of maringo, what dit the trick?
First I created a root password with the help of: "sudo passwd root" procedure and logged in under root with the newly created password.
Then I created the file .asoundrc under the directory root containing:
## Redirect all sound via Bluetooth
pcm.bluetooth {
        type bluetooth
        device AA:BB:CC:10:20:30 # change this MAC address to your speakers address
        profile "auto"
Then I've put sudo in front of the comment in the scripts I've created before. They are now (btw I've created one for "off" and one for "on"):
#!/bin/bash
sudo /usr/bin/mplayer -ao alsa:device=bluetooth /media/alarm_ingeschakeld.mp3 -softvol -volume 90 -af resample=16000:0:0
Then rebooted the pi and yes it's now working with the dummy switch!
Thank you all, and hopefully somebody else can benefit from this thread as well.
