It took me a while to find out but i guess the following occurs: When the temperature reading gets below 0,0 deg C the RFXtrx433E stops receiving the readout values.
The Alecto display unit continues below zero degrees so the sensor is transmitting. The wind readouts continue to be received.
It seems that the "-" sign messes up the logic of the readout.
Can you help me with this?
Thanks!!
Alecto WS4500 stops when below 0,0 degrees
- gizmocuz
Re: Alecto WS4500 stops when below 0,0 degrees
Did you try with the RFXCom RFXMngr application ?
b_weijenberg
- Target OS: -
please contact support rfxcom.com for a beta version 251 which solves negative temp problem
RFX-433, RFX-433EMC, RFX-868
Thanks. I will give both responses a try. I will keep you informed.
