Lua scripting kaku
Posted: Thursday 21 January 2016 21:28
by riegman
I try to call a script for my kaku devices.
The log is written but the script won't run.
Can someone help me with this newbie question?
Thanks in advance.
Greetings,
Robin
-- script name : script_device_kaku.lua
local sensor = 'Lamp1'
if (devicechanged[sensor] == 'On') then
os.execute ("sudo ~/wiringPi/examples/lights/kaku A 1 on")
print ('Aan!!!')
os.execute ("sudo ~/wiringPi/examples/lights/kaku A 1 off")
print ('Uit!!!!!!!')
Re: Lua scripting kaku
Posted: Thursday 21 January 2016 21:44
by SweetPants
I think your problem is the 'sudo'. It needs a password i think
Posted: Thursday 21 January 2016 22:27
by riegman
Isn't that only needed when I use su?
Posted: Friday 22 January 2016 7:24
by jannl
That depends on the sudo settings. When you issue the command commandline, does it work?
Posted: Friday 22 January 2016 8:36
by riegman
When I run it on command line it works and no password is asked.
