2 channel relay at low voltage
Posted: Wednesday 20 January 2016 21:32
I would like to add a 2 channel relay (or just 2 separate relays) with the 433 mhz protocol. I want to be able to switch it on with a command and off with another command just like the kaku switches.
First let me tell you why I want it. I want to switch the power of 2 usb devices, so I want to switch 5V with the relay.
However, I am seeing all kind of relays. They are stating all kind of things like 20A 14VDC or 10A 30VDC together with 10A 28VDC etc.
Can someone tell me if this kind of relay is possible to switch 5V? And if it is even possible to control such a relay with Domoticz?
Thanks in advance!
Thanks in advance!
