Collecting data from watermeter (sensus)
Draakje
- Domoticz version: 4.11539
Hi All,
I am planning in expanding my Domoticz system to include data from the watermeter.
Ofcourse I have search this forums (and google) but I find the found information a bit unclear.
First let me explain what I have:
I have the Domoticz software running on Ubtuntu and read out the smart meter via USB on the P1 port. This works like a charm.
Nothing else is done hardware/software.
Now I have read about the CNY70. Which seems to me the way to go. But this is connected to the PiFace (which I don't have). The part that is unclear to me is how does the PiFace communicate with Domoticz. I have seen the setup/installation but it is talking about rasppi (which I don't have). Maybe the installation is the same on Linux ? How do I connect the PiFace to my Ubuntu ?
In near future I also want to read out my CV (like tapwater and heating) and beside that I want to have the readings of the Solar panels which I am planning to buy (with a Solaredge)
I can find information about Solaredge and CV on this forum ( haven't really read into it) But my main question is about the PiFace for reading my Sensus watermeter.
Ronald
Ronald
Hardware: Raspberry Pi 3, OTGW, 433MHz Superheterodyne 3310 RF Link
Software: Ubuntu 16.04, Domoticz v3.5468, WiringPi, rc-switch
- bierlaagh
- Domoticz version: 4.9984
Re: Collecting data from watermeter (sensus)
You can also build it using a aurduino at this moment I'm building one myself
https://www.mysensors.org/build/pulse_water
1x Raspberry PI 3 With Domoticz V.3.7318
1X RFXtrx433 USB 433.92MHz
1X Synology DS213j Nas
Toon by Eneco including Toon Zon
several KAKU switches and dimmers
Mysensors WIFI Gateway including meters, switches en humidity sensors
Wifi Dimmers (home made)
Draakje
Thanks for you reply. I had seen the page you are referring.
As I don't have an Aurduino board I will have to buy this as well.
As I am very new to domoticz, how do I connect this to domoticz ?
- bierlaagh
The easiest way is to connect it trough USB.
Draakje
ok,
Thanks for the reply
ccclapp
HI
I am new here, but not to HA. I use an ISY: https://www.universal-devices.com/resid ... zw-series/
I am a kickstarter supporter of the below water meter/controller. I know it will be compatable with ISY and also controllable via wifi. I imagine domoticz will be able to interface with is.
http://www.waterheroinc.com/
- gizmocuz
Why do you think this ? (I imagine domoticz will be able to interface with is)ccclapp wrote:HI
Also nothing wrong with the mysensors method, total cost will be < 10$ if you do some good shopping
ccclapp
Hi thanks for the reply. Nice to join the group here.
The WaterHero is a robust device that monitors and controls water flow, emergency shutoff, reporting, etc. It is intended for protection and management.
I am not familiar with mysensors, but for monitoring only at $10, that's great.
I look forward to learning more about your site/creation.
Thanks!!
Thanks!!
ccclapp
Hi a followup if I may: I do not have a "smart" water or gas meter. Can mysensors handle that? What meter requirements does mysensors have?gizmocuz wrote: Also nothing wrong with the mysensors method, total cost will be < 10$ if you do some good shopping
- bierlaagh
Have a look : http://www.mysensors.org/build/pulse_waterccclapp wrote:Hi a followup if I may: I do not have a "smart" water or gas meter. Can mysensors handle that? What meter requirements does mysensors have?gizmocuz wrote: Also nothing wrong with the mysensors method, total cost will be < 10$ if you do some good shopping
At least a normal watermeter can be monitored with my sensors and domiticz
As long as they have some sort of a wheel witch can be monitored
Send using Tapatalk
ccclapp
great
thanks
thanks
