Only Wakeup interval as configuration item
djdehaan
Domoticz version: 2023.2
Post by djdehaan »
I have 2 FIBARO FGMS001 Motion Sensors. With the first I have a long list of configuration items (Hareware/zWave+/Setup, then select the node). With the other I only have one item: the Wakeup interval! How can I get the whole configuration for the second one?
I use a Aeotec Z-Stick Gen5 on a Windows machine, running the latest stable Domoticz.
DJ
djdehaan
Re: Only Wakeup interval as configuration item
Post by djdehaan »
I Excluded it and again Included it. Now I see all the config items. Weird.
blitzkneisser
Domoticz version: stable
Post by blitzkneisser »
If this happened right after including the motion detector to the network, the communication between controller and detector was most likely not finished before the motion detector went to sleep mode. Normally this should either fix itself automatically or you can wake up the motion detector with a triple click.
Quite often the device will show as "unknown" in the list during that period
