Trigger Blockly on specific device status change
markk
Post by markk »
Sorry if this has been asked before but I couldn't find it in a search
I have a blockly that, If door sensor = ON and someone home = OFF send notification. The issue is, my door sensor is always ON. So, if the last person leaves the house, the someone home switch turns OFF and I get a notification because both are now true. However, I only want to be notified if the door sensor changes status when someone home = OFF. Is it possible to specify only one status change to trigger a Blockly event?
imautohuttraeger
Domoticz version: latest
Re: Trigger Blockly on specific device status change
Post by imautohuttraeger »
A quite old posting without any reply. I have a similar challenge: A Blockly script should trigger something only if a value has changed. In my case I want to change a user variable if the the energy meter (Watt) changes.
Stop, look and listen.
imautohuttraeger wrote: Sunday 06 December 2020 14:27 A quite old posting without any reply. I have a similar challenge: A Blockly script should trigger something only if a value has changed. In my case I want to change a user variable if the the energy meter (Watt) changes.
This is not possible in Blockly. You wil have to script this in one of the other script alternatives.
imautohuttraeger
OK, many thx for your quick reply!
