Door contact doesn't work on domoticz with espeasy?
Posted: Tuesday 19 January 2016 9:46
by tsleon
Esp8266 programmed with Espeasy software(tested on r48 and r63 versions). Magnetic door contact connected to esp gpio.
Esp sees contact and updates state. Dummy contact on domoticz doesn't see state changes.
Does anybody else have this problem? Esp is configured with right idx-number.
Re: Door contact doesn't work on domoticz with espeasy?
Posted: Tuesday 19 January 2016 10:20
by dannybloe
Have you tried to set the switch in domoticz using an http call in the browser directly? For all I know, EspEasy does just that..
Posted: Tuesday 19 January 2016 11:49
by tozzke
Is the switch in Domoticz protected?
if so... Read this and you'll have to edit the espeasy firmware
Posted: Tuesday 19 January 2016 16:51
by tsleon
Problem solved!
If i use dummy switch on domoticz, status updates ok. If i use dummy door contact, json call is different and status doesn't update. Espeasy doesn't have door contact-device, only switch type. So json call on esp is wrong for domoticz contact.
Posted: Monday 07 November 2016 19:06
by javier77
Hi Tsleon how did you wired the magnetic sensor to the esp? I have a magnetic sensor one is supposed to be on the door the other part has 2 wires i guess one of then goes to the esp pin an the other to ground is this correct? I am using nodemcu d1 mini wich uses esp8266 too but how did you configured it on esp easy like? Thanks in advance
Posted: Monday 14 November 2016 9:30
by tsleon
javier77 wrote:Hi Tsleon how did you wired the magnetic sensor to the esp? I have a magnetic sensor one is supposed to be on the door the other part has 2 wires i guess one of then goes to the esp pin an the other to ground is this correct? I am using nodemcu d1 mini wich uses esp8266 too but how did you configured it on esp easy like? Thanks in advance
Hi!
Yes, sensor wires goes to ground and esp pin. Pin is configured as switch on EspEasys software.
Posted: Sunday 06 May 2018 16:22
by ruudjeeee
can you tell me how you conected the wires. and can you tell me how to setupp easy esp and domoticz
Posted: Sunday 06 May 2018 16:44
by jvdz
Déjà vu
