Page 1 of 2
Dahua Ip camera snapshot url
Posted: Sunday 17 January 2016 14:41
by imparator
hi, i searched for the dahua camera snapshot url , on this forum, and internet, but get not a working solution, for this camera
in the wiki i found :
http://<IP address>:9989/onvif/media_service/snapshot?channel=0&subtype=0
also not working,
camera model is : IPC-HDBW-2200
has somebody a working url for this camera ?
thx
Re: Dahua Ip camera snapshot url
Posted: Sunday 17 January 2016 21:20
by nayr
Attached is a screenshot of the config for my Dahua cameras, Ive got four different models and they all use the same config. I dont have anything after snapshot.
Please notice, the preview always shows a broken image when I press test connection.. but otherwise the cameras work perfectly fine, so if your using the test button only to check if its working then you will believe its not functioning, when it likely is.
Posted: Sunday 26 June 2016 23:52
by pfer10
Posted: Monday 27 June 2016 20:22
by sincze
Hi.
On my 4300 series camera I can confirm both work:
http://192.168.*.*:9989/onvif/media_service/snapshot?channel=0&subtype=0
http://192.168.*.*:9989/axis-cgi/mjpg/video.cgi
In domoticz however I use:
http://192.168.*.*:9989/cgi-bin/snapshot.cgi?loginuse=#USERNAME&loginpas=#PASSWORD
Posted: Monday 05 December 2016 20:53
by sincze
Pff.. unable to figure out the Dahua C35 snapshot settings.
It seems port 9989.... no longer available....
Nmap shows: 9989/tcp closed unknown
as to earlier DAHUA ... 9989/tcp open unknown
Posted: Sunday 18 December 2016 22:55
by wooojo
Settings for the camera Dahua HDW1220sp of August 2016
ImageURL: cgi-bin/snapshot.cgi?Channel=0
Port: 80
Test Connection DOES NOT WORK !!!!!!
Posted: Thursday 02 February 2017 23:43
by sincze
wooojo wrote:Settings for the camera Dahua HDW1220sp of August 2016
Port: 80
Tnx also works for 4431c-a
Still looking for working DAHUA C-35 settings
Posted: Friday 03 February 2017 0:13
by markjgabb
download ispy and allow it to find it for you, i find for almost every camera it can get the diffrent streams fairly easily
Posted: Friday 03 February 2017 8:58
by sincze
markjgabb wrote:download ispy and allow it to find it for you, i find for almost every camera it can get the diffrent streams fairly easily
I was looking at the ISPY website only to find it.
That is an excellent idea I totally forgot the possibility. Long time ago I found my first foscam links that way.
Now moved from FOSCAM to DAHUA
Thank you very much I will let you know the results.
Posted: Friday 03 February 2017 14:43
by sincze
sincze wrote:markjgabb wrote:download ispy and allow it to find it for you, i find for almost every camera it can get the diffrent streams fairly easily
ISpy came and found...
All systems operational. tnx @markjgabb
Posted: Friday 03 March 2017 22:02
by Teknor
Which port did you use?
Re: RE: Re: Dahua Ip camera snapshot url
Posted: Saturday 04 March 2017 1:19
by sincze
Teknor wrote:Which port did you use?
Port 80.
Sent from my SM-G925F using Tapatalk
Posted: Tuesday 18 April 2017 1:30
by bmwproboi05
Thanks! I used the cgi-bin/snapshot.cgi?1 in the image link and it worked! May need to see if I can adjust the resolution as it takes awhile to load
Posted: Thursday 16 November 2017 20:07
by rldn
Hi guys,
maybe a reply on an old topic but im still looking for an answer for the following.
I have a Dahua IPC-HDBW8630E-Z and i want a streaming of this cam on my own created domoticz frontpage.
The only thing i can embed is a simple snapshot from
http://IP-ADDRESS:8080/cgi-bin/snapshot.cgi.
I cant manage to make this a stream, only with refreshing the whole page.
Is there another way or url for the live stream for this cam?
Posted: Wednesday 21 March 2018 14:31
by torrie0712
I have the same problem. I also can't see a stream from my camera. I have an Dahua IPC-HDBW4431R-ZS.
In Blue Iris i can find my camera and i get the following settinga
Opening 192.168.178.10 port 80...
HTTP Get / request...
OK
ONVIF GetSystemDateAndTime
2018-03-21T13:28:06.000Z
Requesting device information...
Bad response
GetCapabilities...
Querying services
Has Imaging services: /onvif/imaging_service
Has media services: /onvif/media_service
Has RTP_RTSP_TCP, requesting profiles
Has Event services: /onvif/event_service
RelayOutputs: 0
InputConnectors: 0
Has Device IO services: /onvif/deviceIO_service
AudioOutputs: 0
Has PTZ service: /onvif/ptz_service
Checking for common cameras...
Foscam FI86xx/98xx compatible?
Foscam FI89xx compatible?
Foscam FI9821 V2 compatible?
Foscam FI9821 media port compatible?
RTSP port open?
RTSP port detected!
Doneg in Blue Iris
Still i can't see a stream in Domoticz. I tried all trhe things suggested here.
Has anyone an idea??
Posted: Wednesday 11 April 2018 11:25
by jordantheripper
sincze wrote: Thursday 02 February 2017 23:43
Port: 80
Hy, I have your model of dahua but I can't connect to domoticz. Can you please tell me your complete cgi command? thanks
update
mi mistake
my dahua camera is Dahua IPC-HFW4431R-Z but still I have find nothing to connect to domoticz.
Some one can help me? thanks
Posted: Saturday 21 April 2018 15:38
by mcestoni
Hello
I have 4 models of dahua cameras
IPC-KW12W
IPC-HFW2100R-VF
IPC-HFW1000S-W
IPC-HDBW1120E-W
and they all work Ok in domoticz
In the field ImageURL : cgi-bin/snapshot.cgi?
Posted: Tuesday 03 July 2018 10:41
by howi42
I also use the Dahua IPC-HDBW4431R-ZS.
To get a snapshot, I can use
http://10.0.0.30/cgi-bin/snapshot.cgi?1
but then I have to type user and password.
I could not found a version where I add user and password to the URL.
Any ideas ?
Posted: Tuesday 03 July 2018 15:07
by Rainman
@howi42
Can you try;
http://user:[email protected]/cgi-bin/snapshot.cgi?1
I believe I have the similar camera and use;
protocol:HTTP
port: 80
imageURL : cgi-bin/snapshot.cgi?1
Test connection does not work, but the image is shown in the overview page.
Otherwise check if you can downgrade the authentication in the camera config itself from digest to basic. (Assuming you have not connected this to the internet).
Posted: Tuesday 03 July 2018 19:02
by howi42
Thanks, but it did not work.
And, I do not see a way to change form digest to basic.
A workaround could be to trigger an alarm manually; that would create a snapshot I could use.
But I am not sure if this can be done.
