Problem Domoticz to control Livolo "curtains" switch
Posted: Sunday 17 January 2016 13:54
by jovo
I bought a Livolo VL-C702-WR device or switch to contol my sunscreen.
Now i am having troubles controlling this device through Domoticz/RFXcom.
The trouble is basically that i cant get it synchronized in Domoticz.
(pushing the touch until it beeps for the second time, release the touch and push it again until it beeps, then press the test button on domoticz. By successfull sync, the livolo beeps again).
I tried to add it manually as switch type: on/off, blinds, dimmer, but non of them worked.
I have a small livolo remote which successfully synchronize with this device/switch, so the RF part seems to be ok.
I also have a number of Livolo on/off swiches and dimmers which are all working fine with this Domoticz/rfxlan setup.
My domoticz version is 2.3784 (ubuntu) and RFXcom version is 250
Who has some tips or suggestions to fix this problem?
Re: Problem Domoticz to control Livolo "curtains" switch
Posted: Wednesday 24 February 2016 18:56
by rammstan
Hello, I have the same livolo model switch ans the same problem.
For me the switch is not beeping after 5 seconds instead The lamps switch On.
i use rfxcom ext 250
Posted: Monday 14 March 2016 9:57
by rammstan
I bought other switches: VL-C702-R. Now it's beeping. I can switch off when i click "on" in domoticz. But very rarely it s possible to swith on the lamp. I don't know why! So GROUP OFF seems to work. please someone could help?
More info here: https://github.com/domoticz/domoticz/bl ... worker.cpp
ctrl+f livolo
http://rfxcom.readthedocs.org/en/latest ... ting5.html
Posted: Tuesday 12 April 2016 0:20
by SHadley1138
Did you ever fix this? my new lively switch, doesn't beep after 5 seconds, it just switches, and i can't pair it
Posted: Sunday 29 May 2016 13:18
by jovo
Bert of RFXcom provided me a fix for this problem.
I expect that he will integrate the enhancements in next firmware release.
Posted: Tuesday 18 October 2016 22:58
by rammstan
I tested the Switch with the RFXCOM Manager with Toggle learning and on/off. It worked, perfectly. So the problem comes from Domoticz. I think it uses the "All Off" and not the "Toggle" Mode. Here the logs of the rfcom manager:
##Set up the Livolo switck as Toggle
Lighting5 command
Packettype    = Lighting5
subtype       = Livolo On/Off module
Sequence nbr  = 7
ID            = 0202 decimal:514
Unit          = 1
Command       = Toggle
Signal level  = 0  -120dBm
Packettype        = Receiver/Transmitter Message
subtype           = Transmitter Response
Sequence nbr      = 7
response          = ACK, data correct transmitted
##Test toggle to switch off (is working)
Lighting5 command
Sequence nbr  = 8
Unit          = 1
Command       = Toggle
Sequence nbr      = 8
##Test toggle to switch on (is working)
Lighting5 command
Sequence nbr  = 9
Unit          = 1
Command       = Toggle
Sequence nbr      = 9
Posted: Sunday 08 January 2017 17:31
by springfield
Is their a solution for this? I am having trouble with my curtain switch (VL-C702WR). I can't control it with Domoticz. When i add a manual switch (Livolo, Curtains) and do Test then it turns of the switch which was on. Once added, i can't use it to control the curtains.
