Thermostat Group or Scene
Posted: Saturday 16 January 2016 19:37
by trollmar
I ordered 5 Danfoss LC13 Thermostats.
There are working. Can set setpoints.
Is there a way to set Setpoints for more thean one Thermostat at once?
There are Groups for switches ..why not for Thermostats?
Thx
greets to the community
Re: Thermostat Group or Scene
Posted: Saturday 16 January 2016 20:51
by mKotek
Would you be able to share more information on Danfoss setup. There is a couple of mixed info about Danfoss working with Domoticz here and on internet.
I have read, they are working fine with UZB1 stick and Domoticz, but there is no room temp reported back to the controller, right?
Posted: Saturday 16 January 2016 23:02
by trollmar
mKotek wrote:Would you be able to share more information on Danfoss setup. There is a couple of mixed info about Danfoss working with Domoticz here and on internet.
Working with Aeon Zwave Controller Stick.
And yes no room temp back from the thermostat. But I guess this is a off-topic.
Back to Topic:
Maby it is possible to this with a "virtual Thermostat"?
I could find a topic in the forum the helps me out.
Can someone help me?
Posted: Sunday 17 January 2016 10:18
by gizmocuz
Maybe it works with blockly/lua, you could make a virtual switch
if switch = on then
set setpoint 1 to xxxx
set setpoint 2 to xxxx
set setpoint xx to xxxx
end if
Posted: Sunday 17 January 2016 18:04
by trollmar
gizmocuz wrote:Maybe it works with blockly/lua, you could make a virtual switch
if switch = on then
end if
Thx for your idear!!
But I would like to set a Thermostat Setpoint for more then one Thermostat.
In your idear i have to create three virtual Switches for example 5.degress 15.degress and 22.degress.
Best regards
Posted: Sunday 17 January 2016 18:47
by BazemanKM
Could user variables help?
Posted: Sunday 17 January 2016 18:49
by gizmocuz
if switch = on then
end if
Best regards
i suppose that is a lot of work
Edit: might be much more work when i have to code this nattily ?
Posted: Wednesday 20 January 2016 21:51
by trollmar
Hi.
I solved it with this
www.domoticz.com/forum/viewtopic.php?f=31&t=7244
Ok its not so "individual" like set the exact Temperature ..but for two or three Temperature States its perfect!
Greetz
