Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
johansson
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by johansson »
Madgeni wrote: Thursday 15 February 2018 21:13 o_0
It's up - Controlicz is stable - occasionally it bounces when it encounters an error, but it's usually sub 5 seconds, which isn't even enough time for alexa/Google to timeout a response.
Indeed, my (double) mistake - something was wrong with my ddns service and on top of that wrong password to Controlicz :roll: Works like charm again, so donated a fews beers. Great service, I must say; teaches my kids some English as well as they are turning off house lights with Alexa/Controlicz when leaving to school or playing some Spotify.
jungleman
Post by jungleman »
What port number do i have to forward . I already use the Domoticz app outside my Home. I Made a Flore plan, but i don’t know how to set domoticz to https and how do i check if this works ?
Madgeni
Post by Madgeni »
the port is the one you already have forwarded - and you need Room plans, not floor plans :)
matzeb74
Domoticz version: newest
Post by matzeb74 »
Still an error while asking for "Luftfeuchtigkeit im Wohnzimmer" Only Temperature still works.... :-(
tjabas
Post by tjabas »
I have a android tablet on the wall where i controll domoticz from, can i use the "ok google" on that tablet to controll domoticz?
or do i need to buy a google home for that?
Fred78
Post by Fred78 »
tjabas wrote: Sunday 18 February 2018 0:13 I have a android tablet on the wall where i controll domoticz from, can i use the "ok google" on that tablet to controll domoticz?
I guess that it depends on the version of Android that's installed on your tablet. If it's a compatible version, you just have to install Google Assistant and your tablet will behave just as a Google Home.
tjabas
Post by tjabas »
ok, thanks, butis it hard to get controlicz to work with it and do i need to install something on my rasp pi where i run domoticz to get everything to work, or do i just get an account at controllicz?
Madgeni
Post by Madgeni »
Hi tjabas:
https://www.controlicz.com/faq
This tells you what you need to do. No install is needed, get your Domoticz accessible via the internet, add devices to a Room Plan, create a Controlicz user on your Domoticz, then register with Controlicz. Put in your domoticz host details, that domoticz account, then enable the app via Google Assistant
Madgeni
Post by Madgeni »
Hi - yet another gentle reminder, if you're using Controlicz for business purposes, please drop a few pounds in the tip jar. More than happy for you to use it, but help a poor dev out :)
zeppy14
Post by zeppy14 »
First, I would like to congratulate you for Controlicz: very good Job. Thanks.
I have test Controlicz this Week-end.
I have a Rasp Pi 3 with Rasbian up to date with a Domoticz.
My Domoticz is accesiblle via Internet with Https of the specific port 104XX
My device in a Room Plan
I have Controlicz user
I am register with Controlicz => the first connectivity test is NOK, I tried again with the same paramater, it was OK
I have enable the app via Google Assistant => the first device synchro was NOk (unable to connect), the second with the same paramater was ok !!
My Devise are in app Google Home
When I test
"Ok google lights the lamp"
Google Home answers" The device Lamp is on"
But nothing is On in my Domoticz :-(
Can you help me ?
PS : I am French, I use google home in French !!
ArturK
Post by ArturK »
Madgeni wrote: Sunday 18 February 2018 19:25 Hi tjabas:
Hi, I just registered in Controlicz as [email protected].
Add me please to beta testers, now I have error: Controlicz is unable to connect - please check your config. When I linking my Google Assistant there is problem too "check your connection".
- my Domoticz server is accessible via internet (https protocol, public IP and 443 port)
- I have devices in a Room Plan
- I have my user in Domoticz
- I have registered with Controlicz
Is there some tutorial step by step? I think it will be very helpful.
Thanks.
Raspberry Pi 2B, Logitech Harmony Hub, Z-Stick GEN 5.
Sammyc
Post by Sammyc »
Hi struggling to get Home to recognise my devices, its unclear to me where its falling down.
I have done all the Controlicz account stuff and I get confirmation from the website that it can access my Domoticz server, I have linked my account but I see nothing in Home.
Should I see something in the device list like I do with my chromecasts?
Do you think it might be useful to add something to the website so that it can list the devices it sees in case I have my room plans incorrect?
Madgeni
Post by Madgeni »
ArturK wrote: Monday 19 February 2018 12:51 Hi, I just registered in Controlicz as <redacted>.
Thanks.
Hi - it seems to be working fine - i can see lots of requests from you for discovery, as well as controls of some devices?
Madgeni
Post by Madgeni »
zeppy14 wrote: Monday 19 February 2018 12:18
When I test
Can you help me ?
Hi there, is this you?
https://...hd.free.fr:10443 ?
raptorjr
Post by raptorjr »
Deleted, wrong Controlicz thread.
zeppy14
Post by zeppy14 »
Madgeni wrote: Monday 19 February 2018 16:19
When I test
Can you help me ?
Yes is me !!
Do you see something ?
Madgeni
Post by Madgeni »
Yes, it seems to be working ok? I can see sync requests, as well as switch controls
zeppy14
Post by zeppy14 »
Ok have try again ... It don't work :-(
I have change th name of the device. I delete the space in the name (Prise 2 => lumiere) but it don't work.
Do controlicz use the device idx from Domoticz ?
Can I see a log of controlicz to control the resquet (if it's possible send me in privat)
I test this request, it's work fine.
https://login:[email protected]: ... itchcmd=On
Madgeni
Post by Madgeni »
ok, can you unlink the app in your GH and relink it?
zeppy14
Post by zeppy14 »
Ok I do that.
The GH can see the T° of PI but the command "on"-"Off" the light doesn't work !!
