Locked
wizjos
Re: Dashticz v2.0, custom positioning and multiple screens
Post by wizjos »
b00n wrote:Can someone explain the blocks and columns ?
or show an example of there config.js? :D
See http://www.domoticz.com/wiki/Dashticz-v2
EdwinK
Post by EdwinK »
wizjos wrote:Just noticed this. Although it is possible to give an alternative title to a block (blocks[140]['title'] = 'Temperatuur';), this goes for all 'sub-blocks'. In my case I have a 'buienradar-temperatuur' at idx 140 which produces 2 blocks: one for temperature and one for humidity...
I would be nice to give these sub-blocks different titles so I get 'Temperatuur' for the temperature and 'Luchtvochtigheid' for humidity.
Something like
blocks['140_1']['title'] = 'Temperatuur';
blocks['140_2']['title'] = 'Luchtvochtigheid';
Regards,
Wizjos
Got exactly the same problem.
axelbaas
Post by axelbaas »
Maybe this question is already asked. But is it possible to change the size of the icons? On a smaller screen, like a iPad, the icons are too small to click them.
I've tried some custom css, but cannot find the right option (yet).
repoman
Post by repoman »
Something like
Regards,
Wizjos
Or make it possible to use the data field so you get both readings in one block: "Data" : "12.2 C, 54 %"
maluko
Post by maluko »
you have to think like this:
each screen have by horizontal 'width' =12
this 12 you have to divid for column so you can put like this
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
this mean you have the column 1, 2 and 3
column 1 + column 2 + column 3 = 12
(5) + (5) + (2) = 12
in code
//var columns = {}
columns[1] = {}
columns[1]['blocks'] = []
columns[1]['width'] = 5; //this is the width of first column
columns[2] = {}
columns[2]['blocks'] = []
columns[2]['width'] = 5; //this is the width of second column
columns[3] = {}
columns[3]['blocks'] = []
columns[3]['width'] = 2; //this is the width of thirt column
so inside each column you can put the blocks likley the column
each column have width = 12 so you have to divid how many block you want.
block 1 + block 2 + block 3 + block 4 =12 this block will appear in same size
(3) + (3) + (3) + (3) =12
block 1 + block 2 + block 3 =12 will appear 2 with the same size and 1 bigger
(3) + (3) + (6) =12
var blocks = {}
blocks[1] = {} // 1 means sensor/switch idx by domoticz
blocks[1]['width] = 3
blocks[28] = {}
blocks[28]['width'] = 3;
blocks[204] = {}
blocks[204]['width'] = 3;
blocks[342] = {}
blocks[342]['width'] = 3;
OR
var blocks = {}
blocks[1] = {}
blocks[28] = {}
blocks[204] = {}
blocks[204]['width'] = 6;
you can also create title for each column with the same logical:
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Temperaturas';
this will put the blocktitle width the widt of column
and ending you have to set the blocktitle, blocks, etc on column like this
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',1,28,204,342] //if idx produces 2 blocks (temp + humid),  you can use: 'idx_1' and 'idx_2'
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather']
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','horizon',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
basicly this are the explaination that i can give you.
next see the wiki that get undersand more thinks.
madrian
Post by madrian »
So if a device (BME280) produces 3 block (Temp + Humidity + Baro) I should write:
columns[4]['blocks'] = ['blocktitle_2',48,'24_1','24_2','24_3']
or
columns[4]['blocks'] = ['blocktitle_2',48,'24_3']
? I tried both, but I am unable to produce one block combined with the 3 data.
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
hpapagaj wrote:So if a device (BME280) produces 3 block (Temp + Humidity + Baro) I should write:
or
And ive you try just 24?
madrian
Post by madrian »
SwordFish:
Same as "columns[4]['blocks'] = ['blocktitle_2',48,'24_1','24_2','24_3']" === 3 separate columns.
madrian
Post by madrian »
Anyone interested?
Dashticz v2 Internet radio stream plugin
Some code cleaning and going to merge request.
pkrabben
Domoticz version: 3.5877
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Post by pkrabben »
hpapagaj wrote:Anyone interested?
This looks nice
Verstuurd vanaf mijn SM-T815 met Tapatalk
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Can i expect the merge request tonight before the next round of fixes i am going to do? Image
madrian
Post by madrian »
I'll do the best, if you can answer my BME280 temp+hum+barometer question. :D
Ignoring the joke, I'll do my best, but I found a bug in Safari: auto playing is not working when I hit next, prev buttons. Other browsers are fine (Firefox, Chrome). We'll see If I find any workaround.
robgeerts
Post by robgeerts »
I'll do my best too ;) did you mean chrome instead of safari?
madrian
Post by madrian »
robgeerts wrote:I'll do my best too ;) did you mean chrome instead of safari?
Yep, just a typo. :)
pvm
Domoticz version: 4.10538
Post by pvm »
For people with the weer.nl issue, you can also use the bigger buienradar screen like the one in part 1.4 you can find here
I have my new tablet now (very happy with the high resolution screen). I however experience the same issue as with my iPad, I do not get any domoticz data on the dashboard. I've been thinking about this and have to test some more for the possible cause. I am running Domoticz on a PI and the dashboard on my synology nas, possibly the remote calls are causing this issue.
My phone started complaining 'Domoticz error! Please, double check the path in _HOST_DOMOTICZ-variable!'. I upgraded today to the latest version (was running a couple of days behind). I tried the URL with and without username/password showing the same result. On my laptop however, I do not experience these issues. Strange.. any other people having a similar setup (PI with dashboard running on NAS) ?
Other issue, after some time i start getting the following errors in my console log:
Ierlandfan
Post by Ierlandfan »
Rob, i am scraping some site wich in turns writes out a txt file. Is there any way I can show the content in a block, just like the rss feed?
b00n
Post by b00n »
var screens = {}
screens[1] = {}
in code
//var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
(3) + (3) + (6) =12
var blocks = {}
blocks[28] = {}
blocks[204] = {}
blocks[342] = {}
OR
var blocks = {}
blocks[1] = {}
blocks[28] = {}
blocks[204] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
Thnx i'm gonna lock myself up this night ;)
Ierlandfan
I was thinking of adding a function like this:
function FileHelper()
    FileHelper.readStringFromFileAtPath = function(pathOfFileToReadFrom)
        var request = new XMLHttpRequest();
        request.open("GET", pathOfFileToReadFrom, false);
        request.send(null);
        var returnValue = request.responseText;
        return returnValue;
var text = FileHelper.readStringFromFileAtPath ( "/localdir/mytext.txt" );
And then i sorta lost it by putting the output in a textblock.
Edit: Found the xml version..no scraping needed. I am gonna modify news.js to suit my needs.
jake
Post by jake »
Please help a starter (me) to update the Wiki with the procedure to download (and for next time) update the files from gitlab. I cant find it online how to do this.
Blueone
Post by Blueone »
jake wrote:Please help a starter (me) to update the Wiki with the procedure to download (and for next time) update the files from gitlab. I cant find it online how to do this.
http://www.domoticz.com/wiki/Dashticz-v ... ugh_Gitlab
Locked
