Page 49 of 76
Re: Pass2PHP
Posted: Friday 10 May 2019 20:00
by sincze
Trigun wrote:Trigun wrote: Friday 10 May 2019 19:28
Trigun wrote: Friday 10 May 2019 19:13
ok, now I know for sure that my cron is not working
because when I manually start the cron.sh script I get the lg line in the domoticz.log
so, back to the cron
ok, I think I got it.
2 things - the cron.sh was not executable so I did a chmod 777 to cron.sh
and I found out that I used "sudo crontab -e" instead of crontab -e.
now I see the script is running perfectly every minute
just keeping you all informed as it might help others as wel.
Hahaha sudo crontab -e / elevated user
crontab -e .. would be the pi user
Strange that you experience all these things. Well done. Making progress. Weekend just started
Sent from my ONEPLUS A6003 using Tapatalk
Re: Pass2PHP
Posted: Friday 10 May 2019 22:17
by Trigun
sincze wrote: Friday 10 May 2019 20:00
he guys just found out that when I have the following code in _cron60, the auto off for just Bijkeuken does not work.
<?php
lg('this is __cron60');
if ($d['Bijkeuken']['s']=='On'&&$d['PIR-Bijkeuken']['s']=='Off'&&past('Bijkeuken')>60) {
sw('Bijkeuken', 'Off');
if ($d['Garageportaal']['s']=='On'&&$d['PIR-Garageportaal']['s']=='Off'&&past('Garageportaal')>60) {
sw('Garageportaal', 'Off');
but when I leave "&&$d['PIR-Bijkeuken']['s']=='Off'" out of the code, it does work.
I checked the code with php codecheckes but everything seems fine.
don't know where this goes wrong
Re: Pass2PHP
Posted: Friday 10 May 2019 22:18
by Trigun
Trigun wrote: Friday 10 May 2019 22:17
<?php
and for Garageportaal it works fine
Re: Pass2PHP
Posted: Saturday 11 May 2019 5:28
by Egregius
Check the status and name of the pir in the devices table. If that's the question, hard to find the new posts in all these quotes.
Re: Pass2PHP
Posted: Saturday 11 May 2019 8:32
by Trigun
Egregius wrote: Saturday 11 May 2019 5:28
I triple checked the device name but there is no difference.
I did change the cron.sh file as I didn't need most of the lines(so I thought), see attached.
- 2019-05-11 08_25_55-_var_www_html_secure_cron.sh - Domoticz-NEW! - Editor - WinSCP.png (39.63 KiB) Viewed 2185 times
so basically when I keep the
this is a mystery to me.
Re: Pass2PHP
Posted: Saturday 11 May 2019 14:15
by Trigun
Hi Guys,
just wanted to let you know that I got both Garageportaal and Bijkeuken working.
I guess there was something in the devicenames that was wrong so I renamed Bijkeuken to Berging and it all works amazing!
Thank you for all you efforts in helping me out with this issue!
Re: Pass2PHP
Posted: Saturday 11 May 2019 15:49
by sincze
hahaha
you figured it out nice!
I always copy the name from domoticz directly, in case of a missing " " (space) or something.
Just updated my install to the described cron.php and now all is working without cache
Also rewrote the crontab to use the
/usr/bin/nice functionality/
# Check if Domoticz is still running else restart
# */1 * * * * root /home/pi/domoticz/scripts/system/domoticzmonitor.sh >/dev/null 2>&1 # Monitor if Domoticz is still running
* * * * * root /usr/bin/nice -n20 /home/pi/domoticz/scripts/system/domoticzmonitor.sh >/dev/null 2>&1 # Monitor if Domoticz is still running
*/2 * * * * root /usr/bin/nice -n20 curl -s "http://127.0.0.1/secure/pass2php_include/cron.php?cron120" >/dev/null 2>&1
0 * * * * root /usr/bin/nice -n20 curl -s "http://127.0.0.1/secure/pass2php_include/cron.php?cron3600" >/dev/null 2>&1
I use a bit of a different directory stucture but that does not matter.
Did not find out where in his code @egregius did hide the calling of _cron300.php (the 5 minute cron).
- Cron Working.JPG (18.05 KiB) Viewed 2175 times
Re: Pass2PHP
Posted: Saturday 11 May 2019 18:09
by Egregius
Cron300 is called the same way as cron120 but then with */5
Only cron10 and cron60 are called from within the cron.sh script.
Re: Pass2PHP
Posted: Saturday 11 May 2019 18:36
by sincze
Yeah thought so as well.
Check:
https://github.com/Egregius/PHP-Floorpl ... re/cron.sh
The example of the crontab in the first few lines may be a bit 'misleading' for the new guys as the /5 is missing
Re: Pass2PHP
Posted: Saturday 11 May 2019 19:41
by Egregius
I just added those yesterday...
And new guys have to search and learn a bit so they understand the concept.
Re: Pass2PHP
Posted: Saturday 11 May 2019 19:52
by sincze
Egregius wrote:I just added those yesterday...
Yes with the concept in mind it is indeed easier to figure out what goes wrong and why. It just came to my attention.
Re: Pass2PHP
Posted: Wednesday 15 May 2019 13:26
by Trigun
Hi Guys,
still fiddling around with PHP, its getting better and better.
perhaps you can explain to me why the following script is doing exactly the opposite.
<?php
$items=array('Dimmer-Woonkamer-Achter','Dimmer-Woonkamer-Voor','Dimmer-Woonkamer-TV' );
foreach ($items as $item)
if ($d['Woonkamer']['s']=='On') {
sw($item, 'On');
If I switch Woonkamer On, nothing happens. If I switch Woonkamer off, everything the items are going On
Re: Pass2PHP
Posted: Wednesday 15 May 2019 13:57
by Egregius
Is this a device script or a cron script?
If it's a device script I would change $d['Woonkamer']['s'] to $status because $d holds the previous status, not the new one.
<?php
if ($status=='On') {
foreach ($items as $item) {
sw($item, 'On');
Re: Pass2PHP
Posted: Thursday 16 May 2019 11:26
by Trigun
Egregius wrote: Wednesday 15 May 2019 13:57
Works like a charm, thanks a lot!
Re: Pass2PHP
Posted: Friday 17 May 2019 4:33
by Egregius
I'm working on the floorplan to use Ajax instead of just refreshing the whole page.
Before I just did a reload of the page every 3 seconds resulting in 6,7KB each 3 seconds. That's 137KB per minute.
Now the basic stuff is loaded initially and other stuff is fetched 4 times every second (250 msec) resulting in a realtime view of the home with less data. That's done with just 64KB.
Of course when on mobile internet I set the refresh 'slower' to once every second, then there's only 16KB of data needed.
The javascript must be expanded a lot, for now switches, dimmers, thermometers, pirs and contacts are in realtime. Will continue with the other stuff
Re: Pass2PHP
Posted: Friday 17 May 2019 13:35
by Egregius
Almost finished. And damn, it's fast
When I enter a room with a motion sensor, watching the floorplan, I see the light earlier on the floorplan than in reality. I like it
Pass2PHP
Posted: Thursday 30 May 2019 13:51
by Trigun
Deleted due to not paying attention
Re: Pass2PHP
Posted: Sunday 02 June 2019 12:15
by Trigun
please pay attention when installing phpmyadmin with apt-get install phpmyadmin.
when doing so, it will also install apache2 as it is one of the recommendations.
of course this is not a problem when you want to use apache but when you have also installed NginX you have two webservers enabled.
please use sudo apt-get --no-install-recommends install phpmyadmin
with this method you can use NginX as being the main webserver.
Re: Pass2PHP
Posted: Saturday 08 June 2019 21:01
by sincze
Friend of mine has a GoodWe inverter and wanted me to monitor his 32 panels.
Had to create a Pass2PHP solution ofcourse
btw.. it can be used by non Pass2PHP users, but with PHP.
https://github.com/sincze/Domoticz/blob ... Goodwe.php
Re: Pass2PHP
Posted: Sunday 09 June 2019 16:17
by Trigun
Hi Sincze,
What does it do?
I have a goodwe inverter as well and am curious
